Vario Problems
Old August 30th 11, 02:34 AM posted to rec.aviation.soaring
jp4711
Default Vario Problems
My glider is equipped with L-NAV/GPS-NAV. Over the past weeks I have
noticed some problems with the vario. For example it gets stuck and
shows constant lift (visual and audio). Turning the instrument on/off
does not help. Slapping the instrument panel has helped. That makes
me think it is a connection problem of some sort.
On the last flight I noticed that the total energy compensation does
not work. Using my old trusted hang gilding vario (uncompensated) I
noticed that both showed nearly similar lift. Needless to say, that I
turned quite a bit in sink.
Any ideas/suggestions? Your help is appreciated.
Thx. Johann
Old August 30th 11, 01:13 PM posted to rec.aviation.soaring
Dave Nadler
On Monday, August 29, 2011 9:34:32 PM UTC-4, jp4711 wrote:
I turned quite a bit in sink.
Stop turning in sink.
Old August 30th 11, 01:29 PM posted to rec.aviation.soaring
does not help. *Slapping the instrument panel has helped. That makes
Thx. Johann
Send to Gary at ClearNav. The problems you are having are not user
correctable. Gary is quick and
cost very reasonable.
Good Luck
UH
Old August 30th 11, 01:54 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
Thx. Johann
Good Luck
UH
Check all the pneumatic lines, a kink will give the indications you
have................guess how I know?
JJ
Old August 30th 11, 05:07 PM posted to rec.aviation.soaring
bravovictor
Thx. Johann
Good Luck
UH
JJ
JJ, you are truly the voice of experience here. I think every one of
your posts ends with .....guess how I know.
Bob
Old August 31st 11, 12:20 AM posted to rec.aviation.soaring
Discus 44
I had one that had a warped decal inside the meter that caused the
needle to stick. I sent it to Gary for repair. I guess moisture got
into it.
Tom U
Old September 3rd 11, 08:18 PM posted to rec.aviation.soaring
Heinz
Johann,
JJ is right. Check all the air-lines. Just a small slug of water in any of the lines will cause untold problems.
On a dry, sunny day, disconnect all! the instruments from their air-lines, and connect a simple vacuum cleaner to the common line and let it run for about 1/2 hour. Repeat for all the other lines.
That should dry them out.
Heinz
NK Vario Bastoune Soaring 6 December 7th 10 02:18 AM
NK Vario brianDG303[_2_] Soaring 11 September 17th 10 03:38 AM
WTB: 57mm Cambridge Vario/FS: 80mm Cambridge Vario ufmechanic Soaring 0 March 24th 09 05:31 PM
FS: LX-16 Vario [email protected] Soaring 4 February 6th 08 12:20 AM
TE vario G.A. Seguin Soaring 8 June 8th 04 04:44 AM
