Hi Gang
The new Phoenix came without a working TE probe because they had hoped to design their own but designing TE probes is 90% magic and 10% science and they failed. So I needed to change the Tasman Vario with an electronic vario that could operate from the static and pitot lines and calculate a total energy response. There are systems such as the Cambridge (CAI) system that have been around for years that provide this function but I just wanted to change varios. The Westerboer 1020 has the same footprint as the Tasman and the change over was simple in the instrument panel. So I purchased one from Wings and Wheels and installed it. But from the beginning the 1020 kept on going into a lockout condition which required that power had to be removed and reapplied after a few moments. To cut the story short every time I started the motor the Westerboer went into never never land. The transient on the 12 volt power line when starting the engine messed the Westerboer up. The fix was to put a switch on the power supply to the Westerboer and cycle the power after starting the engine. OK some comments. It is clear Westerboer never anticipated the use of the 1020 in motorgliders otherwise they would have found this gotcha. Secondly the LCD display of the 1020 must be viewed head on or else it is unreadable. In the Phoenix with side by side seating the EFIS is on the left side of the instrument panel and the the steam gauges on the right side. So the Westerboer LCD is unreadable by the pilot although the vario function is fine. Does the 1020 perform the total energy function well? Yes it is excellent and much better than the system on my Stemme for example. There is no significent stick thermal effect! Finally I would like to thank Tim Mara of Wings and Wheels for spending the time with me in analyzing the problem with the 1020. Dave |
If it is (high frequency) transcients coming in on the +12VDC/Ground
lines from the engine that is causing your vario problem, then one suggestion is to retrofit a torroid on the +12VDC/ground lines. Like these. http://parts.digikey.com/1/parts/185...a2005-0a2.html. Might help. Couldn't hurt. Good luck. - John |
Hi John
The power cable to the Westerboer Vario came with one ferrite snap core. I added a couple of others but problem remains if I start the engine with the avionics power on. Why would I want to do that? The EFIS takes a couple of minutes to come up and displays important engine info such as oil pressure so the EFIS has to be on when the engine is started. As it is currently set up the vario comes on when the avionics power is applied. That's being fixed. Thanks for your reply. Dave On Sep 8, 12:15*pm, ContestID67 wrote: If it is (high frequency) transcients coming in on the +12VDC/Ground lines from the engine that is causing your vario problem, then one suggestion is to retrofit a torroid on the +12VDC/ground lines. Like these. *http://parts.digikey.com/1/parts/185...lit-snap-core-.... Might help. *Couldn't hurt. *Good luck. - John |
![]() Dave, I have similar comments on the 1020. The Total energy function works very well without the TE probe. Could not ask for anything better here. The display is on the other hand more problematic. Polarized sunglasses are a no go. Bastoune |
Westerboer Vario with electronic total energy compensation | kd6veb | Soaring | 1 | August 3rd 11 08:25 PM |
Electronic total energy vario | kd6veb | Soaring | 13 | July 19th 11 11:23 PM |
Total energy probe orientation? | John Bojack[_2_] | Soaring | 4 | June 5th 09 02:33 PM |
WTB: Sage Model B Netto Total Energy Box | November Bravo | Soaring | 0 | March 15th 05 03:10 PM |
varios not using a total energy probe | Robert | Soaring | 20 | April 25th 04 11:24 PM |
