I just read the following in the Cambridge 302 manual (http://
www.cambridge-aero.com/manuals/302_v3.pdf - page 7) "...used to log Pilot EVents (PEV) in the flight log as mandated by the IGC." I have never heard that Pilot Event logging was *MANDATED* by the IGC. I searched and found the following at http://www.fai.org/gliding/IGC_approved_frs; "Functions such as Pilot Event (PEV) ... may also be incorporated." I then found at http://www.fai.org/gliding/system/fi...Marker_USA.pdf the following; "March 6, 2009 - It is Proposed: To eliminate from the Technical Specifications for IGC-Approved GNSS Flight Recorders the requirement to provide a Pilot Event Marker." So can I assume that the PEV is no longer required to be performed by the pilot? Certainly none of my badge applications have been challenged for not having PEV's. When and why was it required? Thanks, John |
On 9/21/11 3:19 PM, ContestID67 wrote:
When and why was it required? It never was, and nobody could think of a good reason for them, so that is likely why they propose to get rod of them. I've hooked up my PEV to a button on the panel, and will occasionally use it to mark an "interesting" point in my flight. Makes it really easy to find it during analysis. If I fly over an interesting landmark, I can mark it then later look it up on Google Earth, for example. Also used it to confirm my ENL sensor is working at various throttle settings, or as I change ambient cockpit noise. Remember, the GNSS spec came out back in the "dark ages" before there were (many) FR's, so they didn't know what features would be needed. A pilot event could be used in some ways during a contest, I suppose... -Tom |
On Sep 21, 5:19*pm, ContestID67 wrote:
I just read the following in the Cambridge 302 manual (http://www.cambridge-aero.com/manuals/302_v3.pdf- page 7) * * * * * * "...used to log Pilot EVents (PEV) in the flight log as mandated by the IGC." I have never heard that Pilot Event logging was *MANDATED* by the IGC. I searched and found the following athttp://www.fai.org/gliding/IGC_approved_frs; * * * * * "Functions such as Pilot Event (PEV) ... may also be incorporated." I then found athttp://www.fai.org/gliding/system/files/igc_agenda2009_8_6_1_Event_Ma... the following; * * * * * * "March 6, 2009 - It is Proposed: To eliminate from the Technical Specifications for IGC-Approved * * * * * * *GNSS Flight Recorders the requirement to provide a Pilot Event Marker." So can I assume that the PEV is no longer required to be performed by the pilot? *Certainly none of my badge applications have been challenged for not having PEV's. * When and why was it required? Thanks, John The idea, I think, was to make gaggling and leeching harder. You had to push the PEV to declare your "real" start, and could not start again for 15 minutes after that. Then you could sneak off and do a fake start, the leeches follow and then you go back for a real start. Since the rest of the IGC rules make gaggling a necessity, you might see why it wasn't so popular, to say nothing of the complexity. John Ccochrane |
Pushing PEV also set the recording rate to 1 second samples for 30 secnds,
so in early recorders with limited memory, and slow analysis computers, the normal recording rate could be 20 seconds, but pressing PEV while rounding a waypoint ensured a recorded point in the zone. With lots of memory, and much faster analysis, this use is also redundant. The idea, I think, was to make gaggling and leeching harder. You had to push the PEV to declare your "real" start, and could not start again for 15 minutes after that. Then you could sneak off and do a fake start, the leeches follow and then you go back for a real start. Since the rest of the IGC rules make gaggling a necessity, you might see why it wasn't so popular, to say nothing of the complexity. John Ccochrane |
On Wednesday, September 21, 2011 9:31:57 PM UTC-4, John Cochrane wrote:
The idea, I think, was to make gaggling and leeching harder. You had to push the PEV to declare your "real" start, and could not start again for 15 minutes after that. Then you could sneak off and do a fake start, the leeches follow and then you go back for a real start. Since the rest of the IGC rules make gaggling a necessity, you might see why it wasn't so popular, to say nothing of the complexity. John Cochrane Right. IIRC, this was rushed through after the fatal midair in the 1999 Bayreuth pre-worlds (as a means to discourage leeching and resulting traffic concentration). I don't think it was ever actually used in practice. There's an Event Button in the SN10 ;-) You'll see in the SN10 log file something like this: E150305PEVPilot confirmed START Best Regards, Dave "YO electric" |
| Thread Tools | |
| Display Modes | |
| Current SPOT Tracking Events | MarkHawke7 | Soaring | 1 | August 11th 09 03:22 AM |
| chain of events | Capt.Doug | Piloting | 79 | April 7th 07 05:24 AM |
| Upcoming Soaring Events in Pennsylvania | [email protected] | Soaring | 3 | February 11th 07 07:18 AM |
| NNUSAF Upcoming Events | john smith | Piloting | 0 | January 5th 07 10:41 PM |
| Aviation Events Calendar(s) -- Which One(s)? | Jay Honeck | Piloting | 4 | October 8th 05 01:39 AM |
