In-Flight Engine Failure
Old April 8th 04, 03:41 PM
O. Sami Saydjari
Default In-Flight Engine Failure
Well, it happended. I have owned the plane (Piper Turbo Arrow III) for
3 months and the engine failed during climb out on Tuesday. Altitude
was 4400 feet. Luckily, the engine did not entirely quit and I made it
to an airport within 10 miles. TBO was 1000 hours away. Dissapointing!
When we cut the oil filter, it was full of fairly large aluminum and
steel bits of metal. Arg!
(1) Upon examination, the wire into the left magneto was found to be
broken off, just at its connection to the magneto. A mechanic theorized
that it could have grounded to the magento housing. He said that that
could have actually caused a grounding of both magnetos and could have
fouled up the engine firing, and could have contributed to the failure.
Later, he said that he thought that it was just a coincidence that the
left mag wire happened to have been broken when the engine failed due to
some other reason. What do you folks think? Could the two have been
tied togehter?
(2) Now I am faced with having to have the engine overhauled. Growl!
The engine has brand new cylinders on it (well, they have about 100
hours on them) put on by the previous owner. So, I think we want to do
a custom overall of this particular engine. Does that make sense? Are
there different places who do this sort of thing with different
reputations for quality of work? If so, I would like to hear about
recommendations (the engine is a TCM TSIO-360-FB) or perhaps criteria to
use in making a judgement. Also, are there different quality parts or
methods in doing the overhaul that are options that I need to specify
when I ask for the overhaul. In other words, if I can pay 10% more and
get more reliability, then I might like to have the option to do
that...but often, you have to be knowledgeable enough to ask for the
right things.
p3/95 [email protected] Military Aviation 1 September 27th 04 01:27 AM
PC flight simulators Bjørnar Bolsøy Military Aviation 178 December 14th 03 01:14 PM
USAF = US Amphetamine Fools RT Military Aviation 104 September 25th 03 04:17 PM
In Flight Failure Charles Talleyrand Military Aviation 1 August 4th 03 06:25 AM
