Cleaning contacts on fuel senders
Old April 27th 04, 09:59 PM
Ben Jackson
Default Cleaning contacts on fuel senders
I hear that potentiometer-based fuel senders can be revitalized by soaking
them in a solvent to remove accumulated gunk. I'm wondering if they can
be sprayed in place by running the tank dry and using a tuner cleaner
(I think it's mostly dichlorofluoroethane). Will that stuff destroy
fuel bladders or sealent?
Ben Jackson
http://www.ben.com/
Old April 27th 04, 10:58 PM
mikem
Ben,
the problem that these things develop is that the phospor-bronze
wiper contact wears down to the point that it looses contact
with the wire-wound resistance card at certain points in the
arc of travel.
No amount of tuner cleaner will fix that...
They have to come out of the tank. As soon as you can visualize the
little wiper sliding on the resistance wire the problem will become
painfully obvious. You can use an Ohmmeter to measure the resistance
while you are moving the float. AFAIR, the resistance varies from
0 to ~70 Ohms. If at any point in the swing you read "infinity", you
have found your problem spot(s)
There is an outfit in Lock Haven that can o/h them for you.
Be sure to use new gaskets when you reinstall them...
MikeM
Skylane 1MM
spaceship one Pianome Home Built 169 June 30th 04 06:47 AM
Cessna 172 with Wild Fuel Gauge Needle jls Owning 26 February 20th 04 06:56 AM
Yo! Fuel Tank! Veeduber Home Built 15 October 25th 03 03:57 AM
Pumping fuel backwards through an electric fuel pump Greg Reid Home Built 15 October 7th 03 08:09 PM
More long-range Spitfires and daylight Bomber Command raids, with added nationalistic abuse (was: #1 Jet of World War II) The Revolution Will Not Be Televised Military Aviation 161 September 25th 03 08:35 AM
