Positive Tank Pressure
Old April 28th 04, 11:26 PM
Greg Esres
Default Positive Tank Pressure
Anyone have any information about how important it is for a fuel tank
to maintain positive pressure on the inside? I mean *above*
atmospheric.
Part 23 only makes reference to tanks with bladders; these are
required to maintain a positive pressure so they won't collapse.
A C172, though, doesn't have bladders. The forward facing fuel vent
most likely *does* provide positive tank pressure, but that may not
actually be necessary in order to ensure fuel flow.
Old April 29th 04, 01:33 AM
Ben Jackson
atmospheric.
http://www.delta.edu/slime/cancrush.html
Ben Jackson
http://www.ben.com/
Old April 29th 04, 02:58 AM
Mike Rapoport
Clearly it isn't required or the plane couldn't be started while stationary
on the ground.
MU-2
"Greg Esres" wrote in message
atmospheric.
Old April 29th 04, 04:42 AM
Greg Esres
Check out Parts 23.965 and 23.975.
I see nothing of relevance in these two sections. .965 talks about
the pressure that a tank must be able to withstand and .975 talks
about venting...nothing about positive pressure. What am I missing?
Old April 29th 04, 05:23 AM
Greg Esres
All I see on that page is the perils of negative pressure. Of that,
I'm well aware. Doesn't seem relevant to the issue of maintaining
positive pressure.
Old April 29th 04, 05:42 AM
Dave Stadt
The tanks in my plane are not under positive pressure. Haven't been since
March of 1947. I see no reason that they need to be. Gravity hasn't failed
yet.
Old April 29th 04, 12:44 PM
Kyle Boatright
atmospheric.
It isn't important. All you want to do is provide a vent so the tank doesn't
go negative.
Attn: Hydraulic experts - oil pressure relief fix? MikeremlaP Home Built 7 November 6th 04 09:34 PM
Attn: Hydraulic experts - oil pressure relief fix? MikeremlaP Home Built 0 November 2nd 04 06:49 PM
Yo! Fuel Tank! Veeduber Home Built 15 October 25th 03 03:57 AM
Wanted clever PA32 engineer's thoughts - Gear extention problem on Piper Lance [email protected] Owning 5 July 22nd 03 01:35 AM
Pressure Differential in heat Exchangers Bruce A. Frank Home Built 4 July 3rd 03 06:18 AM
