armrest fastening question
Old October 26th 11, 05:19 PM posted to rec.aviation.soaring
Brad[_2_]
Default armrest fastening question
I fabbed up an arm rest/control tube cover yesterday for the LH side
of the cockpit. It will hide the control for the flaperons and
airbrakes PP tubes and also work as an armrest.
I can use fasteners to attach it to the aft cockpit structure and to
the sidewalls of the seat pan, but where it rides up against the
sidewall of the fuselage interior there isn't any way to add threaded
fasteners. I did add a nice flange that follows the inner fuselage
skin contour.
I'm wondering, would a strong Velcro work for this? The unit needs to
be removed occasionally so I cannot permanently attach it.
Brad
Old October 26th 11, 09:14 PM posted to rec.aviation.soaring
Craig[_2_]
skin contour.
Brad
You might look at 3M Dual-lock. It's a heavier duty version of velcro
https://www.bindingsource.com/Produc...FQ40hwod7V1dBA
Sounds like you could also bond a pocket into the fuselage bottom for
the flange to slip into (sounds like a lot of work)
Craig
Old October 26th 11, 09:40 PM posted to rec.aviation.soaring
Dave Nadler
Hi Brad - Snaps work great. Bottom part
is riveted to the glider, top is fastened
through the fabric. Used for Antares
interior.
Look for "Fabric Snaps" at McMaster-Carr.
See ya, Dave
panel fastening ideas [email protected] Home Built 6 May 20th 08 07:21 PM
I want to ask you the most important question of your life. The question is: Are you saved? It is no gasman Soaring 0 August 26th 05 06:39 PM
Question re CNX-80 ROBIN FLY Instrument Flight Rules 6 April 15th 04 04:05 PM
