Powering Mio In The Cockpit
Old November 2nd 11, 12:27 AM posted to rec.aviation.soaring
Dan Marotta
Default Powering Mio In The Cockpit
While I had my panel apart the other day, I noticed the RJ jack in the back
of the 302. Since I had half a Cambridge cable, I plugged it in, powered
up, and measured voltage across the red and black leads - 5v!
I took a standard USB cable that fits the Mio, cut it, and measured the red
and black leads - again, 5v! Tomorrow, I'll connect the two cables together
and run the Mio of the ship's batteries.
Dan
Old November 2nd 11, 12:33 AM posted to rec.aviation.soaring
Paul Remde
Hi Dan,
That is a very bad idea! The RJ connector on the back of the 302 is for
connection to the 303 LCD display. The 303 is a low voltage device. Your
Mio is not. I'm not certain, but I fear you will fry something in the 302.
Best Regards,
Paul Remde
"Dan Marotta" wrote in message
back of the 302. Since I had half a Cambridge cable, I plugged it in,
powered up, and measured voltage across the red and black leads - 5v!
red and black leads - again, 5v! Tomorrow, I'll connect the two cables
together and run the Mio of the ship's batteries.
Dan
Old November 2nd 11, 01:00 AM posted to rec.aviation.soaring
Dave Nadler
Power is NOT the same thing as voltage...
Paul, do you mean "the 303 display is a low POWER device" ?
Old November 2nd 11, 01:02 AM posted to rec.aviation.soaring
Paul Remde
Hi,
I meant to state below that the 303 is a low power device.
Thanks Dave.
Paul Remde
"Paul Remde" wrote in message
Hi Dan,
302.
Best Regards,
Paul Remde
Dan
Old November 2nd 11, 01:39 AM posted to rec.aviation.soaring
C-FFKQ (42)
I bought a 12V-5V DC converter for $10, added a $2 heatsink and wired it into my power lines. Next, I cut off the end of a mini-USB cable and wired that to the converter.
Works great for me, no problems.
-John
Old November 2nd 11, 02:27 AM posted to rec.aviation.soaring
Allan[_4_]
I assume you are powering a Mio GPS - if not then ignore the
following. I'd suggest you wire in a 12v accessory socket then plug
the Mio charger cable into it. If you use a regular mini USB plug into
the Mio I think you will find the Mio will think it is a data cable
and stop any software that is running to try and make a data transfer.
Allan.
Old November 2nd 11, 03:03 AM posted to rec.aviation.soaring
ZL
The 302 manual (pg 25) says pin 4 of the RJ11 is
"+5V = Device power – fuse-limited to 0.9 Amp"
pin 6 and 8 of the DB-9 connector are
"+5 volt power from 302 to connected device; fuse-limited to 0.9 Amp"
I've used the DB-9 connector on my 302 to provide +5V power to an iPAQ
for 7 years now. Cambridge and others have sold connectors for that
purpose for a long time. I also have a 303 hooked up to the RJ11 plug.
Manual is available at the Cambridge website.
-Dave
On 11/1/2011 6:33 PM, Paul Remde wrote:
Hi Dan,
Best Regards,
Paul Remde
the red and black leads - again, 5v! Tomorrow, I'll connect the two
cables together and run the Mio of the ship's batteries.
Dan
Old November 2nd 11, 03:10 AM posted to rec.aviation.soaring
Paul Remde
Hi,
I stand corrected.
Paul Remde
"ZL" wrote in message
m...
I've used the DB-9 connector on my 302 to provide +5V power to an iPAQ for
7 years now. Cambridge and others have sold connectors for that purpose
-Dave
Hi Dan,
302.
Best Regards,
Paul Remde
Dan
Old November 2nd 11, 02:00 PM posted to rec.aviation.soaring
Dan Marotta
Why are my posts red (color, at least on my laptop)?
Thanks, Paul - I did not consider looking up the specs, which I will do.
Dave, I read in the 302 manual about the 0.9A internal fusing in the 302.
The cigarette lighter power cord that comes with the Mio is terminated with
a mini USB connector so there should be no power/data issues. The data
lines are not connected in this case.
I will try to find the power requirements of the Mio online. I opened it up
and it has a small (physically) battery so I suspect its power needs aren't
too big.
I could wire a 12v power cord into the main bus of the glider, but that's
large and there's not a lot of room inside the LAK's panel. Besides, simply
plugging in is so much easier!
I'll report back what (if anything) I find.
Hi,
I stand corrected.
Paul Remde
m...
-Dave
Hi Dan,
302.
Best Regards,
Paul Remde
Dan
Old November 2nd 11, 02:48 PM posted to rec.aviation.soaring
Dan Marotta
Well... All the Mio specs I could find are that it has a 750 mAH battery
which should last for 2.5 hours (and I know from experience that that is
about right). At 5 volts that would indicate a current draw of 288 mA.
I called Mio tech support and they confirmed that number so running the Mio
from a 900 mA port on the 302 should be no problem at all.
Thanks to Paul, for raising a red flag, and to Dave for describing his
setup.
with a mini USB connector so there should be no power/data issues. The
data lines are not connected in this case.
up and it has a small (physically) battery so I suspect its power needs
aren't too big.
simply plugging in is so much easier!
Hi,
I stand corrected.
Paul Remde
m...
-Dave
Hi Dan,
Your
302.
Best Regards,
Paul Remde
Dan
Trying again: Collings Foundation B-17 at Newcastle Airport inDelaware - B-17 cockpit.jpg - B-17 cockpit.jpg (1/5) Jim Breckenridge Aviation Photos 1 August 30th 08 07:36 PM
Trying again: Collings Foundation B-17 at Newcastle Airport in Delaware - B-17 cockpit.jpg - B-17 cockpit.jpg (0/5) Go-dot Aviation Photos 0 August 28th 08 11:39 PM
Wings of Freedom B-17 Wilmington, DE - B-17 cockpit.jpg - B-17 cockpit.jpg (1/5) Waldo.Pepper[_2_] Aviation Photos 0 August 28th 08 10:31 PM
Wings of Freedom B-17 Wilmington, DE - B-17 cockpit.jpg - B-17 cockpit.jpg (0/5) Go-dot Aviation Photos 0 August 28th 08 09:37 PM
Powering JSF: One Engine Is Enough. Mike[_7_] Naval Aviation 42 February 14th 08 09:53 PM
