Hi!
Our 68 Arrow is not what you would call airtight on the door. Is there a part available to seal it better? Where can I find it? It seems like air is leaking in at the lower back end of the door. Will this also help lowerr the noise in the cabin? Thanks, Frode Berg LN-LMR |
http://www.piperdoorseals.com
These are the only seals I've ever had actually work well. They reduce both noise and air leaks. Do the baggage door too, and get the kit for the door pins to make sure that the door is properly aligned. There are 2 side effects. 1. You have to remove the old seal completely including the old adhesive. This is about a 4 hour job. 2. The new seal mounts on the cabin frame and is more vulnerable to inadvertent damage. However, replacements are cheap and easy to install. You only have to replace the damaged section. |
