Before You Buy Slick Magnetos
Old June 23rd 04, 07:08 PM
jls
Default Before You Buy Slick Magnetos
Check out their warranty. It's short and not worth anything for long, or
to a successor owner.
And if you need help from them at Unison by phone, skip it. They're not
interested. And besides you'll be punching buttons on the phone trying to
get to a warm-blooded human being until you're fidgety and exasperated.
Maybe they don't have any warm-blooded humans there anyway.
I have a bad magneto lead and was really just trying to buy a replacement.
They will play phone and e-mail tag with you, ask you stupid questions, then
shove you over into the corner.
The good old Bendix mags are looking much better to me. Besides, when you
replace a lead you don't have to go through a major operation swaging it
into the distributor cap.
And you know something else? I don't know how many Slick mags I have found
on airplanes with the cap backing off the mag because one or more of the
screws has backed out and fallen out of it. It's happened to me with my
personal aircraft twice.
Add that to your preflight list if you have Slick mags: "Check to see that
your distributor cap is still attached to the back of each magneto. Also
check to see that each of the three screws holding the harness onto each
magneto is tight and secure."
Does Slick have any competition? It sure as hell needs it.
Old June 24th 04, 03:11 AM
JDupre5762
I have always found Slick pretty good at answering technical questions anyway,
especially Harry Fenton.
You could buy a replacement lead from any of the major and minor distributors
or your friendly FBO.
I was thinking about writing about the experience I am having with certain
Bendix mags in a Skymaster, two failures at less than 200 hours with internal
nylon and plastic parts melting. (To be fair to Bendix the affected parts are
after market so I really should be mad at ElectroSystems.) I am seriously
considering replacing the AD prone Bendix types with Slicks.
Have never seen this happen on any Slick mag in 20 plus years. Are the screws
properly torqued?
Aircraft ownership; Not for the faint of heart or wallet.
John Dupre'
Old June 24th 04, 04:18 AM
G.R. Patterson III
It's one year. If a mag doesn't break in the first year, it's likely to last a *long*
time. Slick also has an excellent record of honoring claims when a mag breaks shortly
after the warrantee runs out.
That was not my experience in 1997. I wound up speak with the president of the
company when I had a problem.
With that sort of request, they generally refer you to a local dealer. In my case,
that was Pen-Yan.
Then buy some.
Really? Hasn't happened to me. I've owned aircraft with Slick mags for over 15 years.
George Patterson
None of us is as dumb as all of us.
Old June 24th 04, 05:35 AM
Dave Stadt
"JDupre5762" wrote in message
anyway,
Unfortunately Harry left the company a short while ago.
Old June 25th 04, 02:01 AM
Dan Thomas
We have those mags on five airplanes, and the screws have never
backed out on any of them in the eight years I have been looking after
them. These mags fly 3000-4000 hours a year between them.
OTOH, the dual Bendix mag on the R182 is a positive pain in the
Dan
Old June 25th 04, 04:40 PM
jls
"Dan Thomas" wrote in message
om...
found
my
Dan
Ah, OK, Dan, to be fair with Slick and Unison, I will have to say that we
got the harness repaired yesterday and most of it was needing cleaning.
Apparently there was an almost invisible carbon track on a cigarette and a
little carbon on the distributor cap. Afterwards, the engine ran smooth as
silk.
But as for those screws that back out, the news spread, two or three people
got nervous about theirs and sure enough they found some loose and one of
three screws backed completely out and gone.
You may have plenty of space at the back of the mags where you or your
mechanics can get a screwdriver in there and do some serious torquing. On
an aircraft where the fit is close, it is more difficult to tighten the
screw. I remember one where all the screws but one were gone and the third
was loose: the only thing holding the harness to the mag was the tight
space.
Blue Loctite maybe?
As for Unison's offer to give advice at its website, my experience says that
THAT is worthless as the teats on a boar hog. The last time I asked for a
little tech help I got an e-mail after a couple of days wait and a number to
call some chap in Jacksonville. All I could get was his voice-mail. So I
gave up.
Don't get me started on their damn sparkplugs. It doesn't take them long
before they are rusty.
Old June 25th 04, 04:53 PM
Jim Weir
As I recall, you can get those screws with drilled heads for safety wire.
" jls"
-But as for those screws that back out, the news spread, two or three people
-got nervous about theirs and sure enough they found some loose and one of
-three screws backed completely out and gone.
-You may have plenty of space at the back of the mags where you or your
-mechanics can get a screwdriver in there and do some serious torquing. On
-an aircraft where the fit is close, it is more difficult to tighten the
-screw. I remember one where all the screws but one were gone and the third
-was loose: the only thing holding the harness to the mag was the tight
-space.
http://www.rst-engr.com
Old June 25th 04, 09:04 PM
Dan Thomas
" jls" wrote in message ...
om...
found
my
Dan
silk.
space.
Blue Loctite maybe?
Purple is better for small screws (Loctite 222). Not so strong as
to make removal difficult.
gave up.
I'm going to get you started. We find Unisons outperform and
outlast Champions by a wide margin. Champion has a spring-loaded
resistor in their plug that seems to lose contact after a while, and
internal arcing reduces spark strength. Unison's (Auburn's old design)
has a molded-in resistor that gives no trouble at all. We won't use
Champs unless forced to.
Dan
Old June 26th 04, 01:35 AM
jls
om...
Blue Loctite maybe?
that
for a
number to
So I
gave up.
long
Dan
Interesting info. Thanks, Dan. And I'll buy some of that purple Loctite
too. But I have some 3-year-old Unison sparkplugs with good electrodes.
The bodies of the plugs have rusted all to hell. I'll keep them, though,
especially since you have praised their insides.
Old June 28th 04, 03:55 AM
nauga
Nauga agreeing with Larry? What's the world coming to? g
jls wrote...
I plan to tomorrow. I've got either a bad lead or
a bizarre problem with the mag, and they're both
brand new.
found
Add two more to your count. I found loose screws
on both caps last week. They were properly torqued
when installed 25 flight hours ago. Blue thread locker
and inspection lacquer, and you better believe I do the
monkey crawl with an inspection mirror as part of every
preflight now.
Dave 'double jointed' Hyde
RV-4 in flight test
Slick aircraft tires Paul Lee Home Built 7 September 11th 04 07:01 AM
Slick Magneto auction Marc J. Zeitlin Aviation Marketplace 0 August 30th 04 02:18 AM
internal timing of slick magneto Jerry Jensen Home Built 1 June 25th 04 08:59 PM
FA: Slick Mags (used) 600 series with harness BFC Aviation Marketplace 0 June 24th 04 05:21 PM
FS: Slick ignition components (O-540) David Campbell Aviation Marketplace 0 December 24th 03 03:56 AM
