landing gear cleaning
Old July 4th 04, 06:17 PM
Bob Miller
Default landing gear cleaning
What does everyone use for cleaning dirt/grease up on landing gear?
We're not satisfied with soap/water due to the fact the
brush/scrubber/sponge can't get to all the nooks and crannies. A
hangar neighbor suggested brake cleaning fluid.
Thanks
Old July 5th 04, 03:51 PM
Bob Miller
Powerwash with a good detergent
We tried a friend's power washer last year and were not happy...enough
pressure to clean was enough pressure to remove paint :-(
and rinse and then proper lube
afterwards.
Yes, lube is important, lubing after a washing or flying through hard
rain you can see water come out when adding grease
Wipe the exposed chromed parts of the struts down with a
light film of oil.
At least we don't have to bother with that (Mooney)
Old July 5th 04, 09:31 PM
hjarrett
Watch out for the brake fluid. Several kinds will attack paint and the
seals (assuming you have a pneumatic/hydraulic strut) can be damaged by the
brake fluid getting on them. Craigs suggestion of detergent is good but
remember to wipe the chrome on the strut down with the same fluid that's in
the strut before you move the plane. One pass of a dry piston on the seals
can roll or cut them and result is buying an expensive seal kit.
Hank J
"Craig" wrote in message
om...
(Bob Miller) wrote in message
. com...
Thanks
Powerwash with a good detergent and rinse and then proper lube
afterwards. Wipe the exposed chromed parts of the struts down with a
light film of oil.
Craig C.
-----= Posted via Newsfeeds.Com, Uncensored Usenet News =-----
http://www.newsfeeds.com - The #1 Newsgroup Service in the World!
-----== Over 100,000 Newsgroups - 19 Different Servers! =-----
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 1 November 24th 03 03:46 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 2 November 24th 03 06:23 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 0 November 24th 03 04:52 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 07:24 AM
