DG-200 Water Valve
Old December 2nd 11, 06:37 PM posted to rec.aviation.soaring
S. Murry
Default DG-200 Water Valve
One off the dump valves on my DG-200 is not completely closing. It seems
that the spring mechanism that pushes down on the plug to seal it when you
close the dump valve doesn't have enough "oomph" to completely close the
valve. I suspect that a good cleaning might be all that is required, but
if not I might need to replace the spring or make some other repair to the
mechanism.
The valve assembly is housed inside a plastic box in the wing root. The
box is secured by a number of screws. In order to remove the box, you
need (as one of my club-mates observed "Little Elphin Hands."). I don't
have elphin hands, but I do have a large variety of tools with which to
attack this problem.
However, having never removed this valve assembly before, I am looking for
tips or pointers, specifically:
1) Any easy way to remove the screws?
2) Once I get the screws off, what's inside the plastic box? Am I going
to little springs and ball-bearings flying out all over the place once I
loosen the last screw?
3) Anybody have a picture/drawing/procedure related to the valve
assembly?
4) Anything else I should know?
Any and all tips are greatly appreciated.
Stefan Murry
Old December 2nd 11, 07:24 PM posted to rec.aviation.soaring
JohnDeRosa
Suggestion: purchase the "Elfin Hands" service contract from DG. Only
E1,000 a year. (sorry couldn't help it) (actually this is gallows
humor as I am a DG owner).
I have no experience with DG's internal mechanism other than at a
contest a few year's back a pilot had a leaky/drippy valve and used
vaseline to get the rubber seal to seat itself better. Wouldn't hurt
to give that a try before opening the plastic "pandoras box".
Good luck and let us know how things worked out. Post a picture or
two or three.
- John
Old December 3rd 11, 12:13 AM posted to rec.aviation.soaring
S. Murry
John,
Thanks. Actually, I think the previous owner may have already used the
"vaseline trick", maybe too many times. I appear to have a
semi-fossilized covering of what appears to be a vaseline/dirt mixture. I
think this is actually what may be gumming up the works. However,
cleaning it from the outside hasn't proven easy.
Well, if nobody else chimes in, I guess I dig in and hope for the best!
I'll certainly post again with results.
--Stefan
two or three.
- John
Stefan Murry
Old December 3rd 11, 02:50 AM posted to rec.aviation.soaring
Marc
On Dec 2, 4:13*pm, "S. Murry" wrote:
John,
Thanks. *Actually, I think the previous owner may have already used the
"vaseline trick", maybe too many times. *I appear to have a
semi-fossilized covering of what appears to be a vaseline/dirt mixture. *I
think this is actually what may be gumming up the works. *However,
DG does sell a valve rebuild kit, which, as I remember, consists of a
replacement spring, O-ring, and a few other random parts. This did
the job when one of my DG-600 valves started leaking. I didn't do it
myself, so I can't help you there, and you'll likely have to pay the
DG tax to get hold of the kit...
Marc
Old December 3rd 11, 05:03 PM posted to rec.aviation.soaring
S. Murry
Thanks, Marc.
I don't think 1500+ dollars for the rebuild kit is in the cards (1000
euros for the "service contract" + a couple hundred for the rebuild kit,
with shipping). So, wish me luck as I dig in myself...
--Stefan
On Fri, 02 Dec 2011 20:50:03 -0600, Marc wrote:
On Dec 2, 4:13 pm, "S. Murry" wrote:
John,
I
Marc
Stefan Murry
Old December 3rd 11, 06:32 PM posted to rec.aviation.soaring
eric keetels
On 3 dec, 18:03, "S. Murry" wrote:
Thanks, Marc.
with shipping). *So, wish me luck as I dig in myself...
--Stefan
John,
semi-fossilized covering of what appears to be a vaseline/dirt mixture..
*I
replacement spring, O-ring, and a few other random parts. *This did
the job when one of my DG-600 valves started leaking. *I didn't do it
Marc
Stefan Murry- Tekst uit oorspronkelijk bericht niet weergeven -
- Tekst uit oorspronkelijk bericht weergeven -
Hi Stefan,
Do you have a waterballast system like this: http://www.mijnalbum.nl/GroteFoto-KDTAVP3R.jpg
I changed the spring without any problems. It's easy to do.
The size of the spring isn't really that critical, mine comes from a
friends "collection".
You might find one a regular hardware shop.
I made a photoshoot of the whole operation.
Just let me know if you need more details.
Best Regards,
Eric
(the Netherlands)
Old December 4th 11, 04:14 AM posted to rec.aviation.soaring
Marc
On Dec 3, 9:03*am, "S. Murry" wrote:
Thanks, Marc.
Actually, the kit cost me all of US$85 including shipping just 5 years
ago. I've owned three DGs over the years, including one ordered new.
No more, thanks to the service contract lunacy...
Marc
Brass Ball Valve,Gas Valve,Needle Valve,Angle Valve,Hose Bibcock Sale on good price valvetom Piloting 0 November 28th 06 02:25 AM
DG-300 water bag valve Q. [email protected] Soaring 1 February 28th 06 03:20 PM
LS4 Water valve control rod wanted Frank Soaring 3 February 21st 06 05:04 PM
Water dump valve rotary seal Bill Daniels Soaring 6 May 10th 04 11:02 AM
WTB: ASW 27A water valve Peter Van Camp Soaring 0 April 28th 04 10:37 PM
