Best Alodine
Old January 2nd 04, 01:38 PM
Larry Smith
Default Best Alodine
I'm using DuPont's Aluminum Conversion but it doesn't work as well as some
I've seen. I want a little better etch. Also it is too expensive. Who
has a better source? The old literature speaks of a powder form chromic
acid etch. Anybody know where to find it at a good price? Thanks.
Old January 2nd 04, 02:33 PM
Ed Wischmeyer
"Chromic acid etch" doesn't quite sound right. IIRC, chromic acid is the
alodine part, and phosphoric acid is the etch done to prepare the metal,
after surface oils are removed with a solvent.
Ed Wischmeyer
Old January 2nd 04, 02:38 PM
Stealth Pilot
On Fri, 2 Jan 2004 07:38:53 -0500, "Larry Smith"
the standard alodine etch is a dilute phosphoric acid.
dont know what else is in the mix to moderate its action though.
Stealth Pilot
Old January 3rd 04, 02:14 AM
Orval Fairbairn
Stealth Pilot
You can set up an alodine tank and an etch tank. The steps a
1. Thoroughly degrease the aluminum (acetone, MEK, lacquer thinner)
2. Dip etch in a room temperature lye solution for about 3-4 minutes.
You can buy Lewis Lye at a supermarket.
3. Rinse the aluminum.
4. Dip the aluminum in a warm (120 deg F) alodine solution about 10
minutes, or until it gets a light gold color. You do NOT want it to turn
brown! Just a very light gold color is all you need.
5. Rinse the metal.
You MAY be able to get alodine powder from a plating shop -- that's
where I got some a number of years ago.
Always wear rubber (or vinyl) gloves when working with this system.
Old January 4th 04, 04:23 PM
Squirrel
"Larry Smith" wrote in message
Who
I'm a lurker in this newsgroup, but thought I could add something to this
thread.
McDermid Inc. supplies Iridite (another brand name for chromic acid). It is
available for commercial accounts only (Montreal: 514 745-7040). McDermid
has other locations in US (check the phone book or do a Google search).
From their Canada office, they sell it for $237 CDN (about $165 US) for 10
lbs. This makes 128 gallons of solution. That's a lot of chromic acid.
Issue is, how will you then dispose of it? Whatever you do, do not flush it
down the drain or dump it anywhere. Check out your municipal recycling for
hazardous waste (paint, chemicals etc). They probably will not process large
quantities for you though (considered commercial). Also, safety rules must
be followed, as this is a know carcinogenic. Now you can understand why
McDermid only sells commercially ... liability .... you should already know
something about that.
On the topic of safety, did you know that latex gloves are useless for
chromic acid? I double glove with a strong latex glove on the outside
(protects against the aluminum cleaner acid) and nitrile closest to the skin
(protects from the chromic acid). If you don't believe this, then notice the
brown chromic acid on the nitrile gloves that has just permeated through
your latex gloves. You don't want any holes or rips in your gloves.
Good linke for glove effectiveness (you can search based on chemical name):
http://www.chemrest.com/chromicacid%20ranking.htm
Before you use the chromic acid, you must properly degrease the part
(scotchbrite pads, mild detergent, etching solution, proper rinsing ... see
other responses). Dipping will give the best results (gives a nice light
gold finish, unless, of course, you use the clear/transparent version of the
chromic acid).
Once dry, finish it off by painting on a 2 part epoxy primer (Akzo Nobel).
Many other brands (mil spec) of aviation grade epoxy primers are vailable as
well. Only a very thin coating is required. Again, safety! I use a
homebrewed full ventilated mask when painting, and a rigged up paint booth
in my garage.
I buy chromic acid in gallon form (PPG DX 533 ... about $23 US) at my
automotive supply shop. I also use PPG aluminum cleaner, available in gallon
form as well for about $12 US. Found that other brands were more expensive
locally (this may vary by location). Also, I use Dawn dishwashing liquid for
degreasing parts after having used MEK to remove any manufacturing
marks/labels.
I dip all that I can (1 gallon will allow me to dip wing skins). I use
shallow cardboard boxes (Van's boxes from the tail kit is just great), and
line them with 6 mil polyethylene (construction vapour barrier). One for
etch, another for rinse, and a final one for chromic acid. Finally rinse the
part well before letting dry. Parts look really nice when dipped (did I say
that once too many?).
Beware of porous primers which require a paint to seal it off, as their main
function is to enhance adherence to the material. Most automotive primers
are porous, and will allow the metal below it to corrode. Epoxy primers tend
to not require additional sealing
Do your research and use this stuff wisely. Do net searches for other's
experiences, and finally contact the supplier for information on use and
safety.
O.T. Here's more info than you even asked for, though short and sweet :-)
Recipe for Paint booth:
Walk-in paint booth made with a couple of 2x4 hanging across the garage door
ceiling tracks. Cover all with 6 mil polyethylene. Make hole to suspend a 20
inch box fan to pressurize the booth (don't have to worry about fan igniting
flammable paint fumes since it is pushing freesh air in). Open garage door
18 inches and make a frame to fit below it. Fill the frame with paper type
furnace filters. It will catch just about all your overspray. Works for me.
Air supply for my full face respirator:
Bought a full face respirator on ebay ($40 US). Then, go to your aviation
supplier (Home Depot) and get some sump pump tubing (25 ft for about $3 US),
and a central vac wall attachment. Stop off at your local appliance repair
place and pick up a used dishwasher air blower (couldn't find any dead
dishwashers by the side of the street). The blower cost me $7 bucks. Rig
all this stuff together ... sump pump tubing to your face mask, other end to
the permanently installed central vac attachment which is connected to your
blower in another room (or outside) with more sump tubing.
Do clean that blower well before you use it, and NO, don't hook all this up
to your actual central vac plug unless you want the life sucked out of you.
I've had great success with this, and since the blower motor is not part of
the air flow as in other homemade systems (shop vac exhausts etc), you get
cool breathable air with no risk of ozone generated from sparking motors.
Disclaimer: This, of course, is done all at your own risk. It's worked for
me, it's up to you to figure out and decide if any of this information is
suitable to you.
Old January 4th 04, 09:02 PM
zxc
hj
"Squirrel" wrote in message t.cable.rogers.com...
Who
thread.
chromic acid).
in my garage.
marks/labels.
safety.
suitable to you.
Old January 5th 04, 03:17 AM
Larry Smith
some
Who
chromic
thread.
is
Thanks, Squirrel, for all that most delightful information.
Alodine Max Setup time JDupre5762 Home Built 1 September 6th 03 05:40 PM
Alodine Pat Yearick Home Built 2 September 6th 03 08:11 AM
