AI pitch bounce
Old November 28th 04, 12:05 AM
Mike Noel
Default AI pitch bounce
I just noticed today a tendency for my vacuum AI to vibrate a few
millimeters in its pitch axis occasionally, then the movement damps out.
The roll and pitch indication seem to be OK, and the vacuum DG is working
fine. The vacuum guage is at 5.0, right where it belongs. I'm wondering if
this is an early failure indication.
Regards,
http://mywebpage.netscape.com/amountainaero/fspic1.html
Old November 28th 04, 02:51 AM
JDupre5762
snip
I'm wondering if
An instrument shop owner told me once that it is. How long it will take to
fail is the question. This tech also told me that if you put any gimbaled
instrument down on a surface and could hear the case touch the surface you have
damaged the bearings.
John Dupre'
Old November 28th 04, 11:46 PM
Ross Oliver
My AI has done this for as long as I have owned the aircraft (coming
up on 4 years). Of course the gyro shop said, "Needs overhaul"
so last year I sprung for the $200 overhaul. No difference whatsoever.
Although it does spin up a lot faster now. Used to take several minutes,
now it snaps to attention within 5-10 seconds of engine start.
The needle on the vacuum gauge seems to vibrate in sync with the AI,
The face of the gauge also seems to be loose, so my latest theory
is a leaky gauge causing variations in vacuum level. If this is
still the case at the next annual, I may try replacing the gauge.
Old November 29th 04, 11:43 PM
Dan Thomas
"Mike Noel" wrote in message ...
It's caused by engine or prop vibration. The instrument panel
shock mounts might be old and hard, or the prop may need balancing.
Either way, the vibration is reaching the indicator. Next time you
fly, play with RPM settings to see if you can make the indicator
resonate with vibratory fequencies.
Dan
IVO pireps wanted.. high performance/high speed... Dave S Home Built 8 June 2nd 04 04:12 PM
Prop Pitch Question Eugene Wendland Home Built 2 April 25th 04 03:22 AM
ram air pressure governed variable pitch prop Bruce Meacham Home Built 4 April 16th 04 08:42 PM
ALTRAK pitch system flight report optics student Home Built 2 September 21st 03 11:49 PM
Propellor pitch ... Bob Noel Owning 2 July 29th 03 04:30 AM
