Transition to PA-32R
Old December 21st 04, 02:28 PM
Mike Granby
Default Transition to PA-32R
Well, I've now got a grand total of 6 hours in my newly-acquired 1980
Saratoga, and since a couple of people asked, I thought I'd post my
experiences. The first big difference that hit me before I got off the
ground -- it's a heck of lot harder to taxi than the PA-28. Ok, so it
helped a lot when I remembered to turn the yaw damper off (!) but even
then, the longer arm on the steering combined with the higher pedal
forces made for a rather drunken course to begin with.
On take-off, the power was quite a revelation. While my PA-28-151 would
happy trundle down the runway, this thing moves, and you really feel
the acceleration. Rotation comes at more-or-less the same place on the
runway, but at 80kts rather than 65kt. It took me a while to figure out
the right trim setting (forget what the book says) so the first couple
of times, I had to really hawl it off the ground. Probably not the best
technique!
Next big problem -- developing a gentle touch on the levers. The
throttle, prop and mixture all seem more sensitive, and my ham-hands
were making far-too-large adjustments until things start to settle
down. In the air, it flies like a somewhat heavier Warrior. Seems to
need more rudder in the turns, and it's easier to get off altitude, but
after a couple of hours, all that settled down, and I'm reasonably
comfortable with the air work. The stall is non-exsitent, and slow
flight down to 60kts is easier managable.
Touch and goes were fun -- the pattern went around a lot faster than
before, and the workload seemed ridiculously high to start with. As
usual, things started to slow down, although there's still a lot to do
on downwind if you're to get trimmed, GUMPed and ready to cut power by
the end of the runway. Landing was, of course, the hardest bit. I never
came close to fogetting the gear, as I had my instructor shouting
GUMPS! GUMPS! every ten seconds, but I did realize when we did a
straight-in approach to a controlled airport how things like that can
shorten the accident chain...
In the pattern, we aimed for 100kt on downwind, 90kt on base, and then
80kt on final, with the last notch of flaps as we came over the fence.
For some reason I just couldn't stop myself getting fast on the
base-to-final turn, and then I realized that I was losing sight of the
runway behind that long snout, and instinctivly dropping the nose to
sneak a peak at my aiming point. As soon as I figured that, and
persuaded myself that if the runway was there on downwind, it would
probably be there on final, everything got a lot better. Nice early
roundout, work the trim in the flare, and while not every one was a
greaser, I had no problem keeping the nose way off, and producing at
least an acceptable result.
We also did some short-field stuff, which surprised me. The plane had
no problem getting either in or out of a 2400ft strip with way more
than 50% of the runway to spare. In fact, it seemed easier to put in
than my Warrior, which confirms my theory that I always landed that too
fast!!!
Still a lot to do -- instrument stuff, night flight, fully-loaded
flight, and adventured with the as-yet not-turned-on autopilot and
other toys. Still, I need another 9 hours to keep Avemco happy, so
there shouldn't be a problem finding the time. Performance wise, I've
been getting about ~162kt in cruise at 4500ft - 5500ft, so it looks
like LoPresti earned at least some of that money he took from the
last-but-one owner.
Old December 21st 04, 06:17 PM
nobody
Mike,
I use another memory aid in addition to GUMPS.
PUF on final, which stands for:
Prop(s) - set for go around
Undercarriage - confirm it is down and locked
Flaps - final setting for landing
This "PUF on final" check saved me from a possible gear up landing (or
at least explaining to the instructore why I missed the gear check) during
the early days of my retract flying experience. This occurred after an
instructor pulled the gear pump circuit breaker while distracting me with
something else. I did the GUMPS check on downwind, and placed the
gear handle down, the gear dropped but did not fully extend and lock,
the noise picked up, I had extra drag, and it seemed like the gear was
in fact down. However, I failed to comfirm the green lights. After turning
final and doing the "PUF on final" check, I noticed the lights were not on.
Another technique taught to prevent the above senario is to leave your
hand resting on the gear switch until the down and lock indicators are
illuminated. If you don't move your hand off the switch until you confirm
the gear is down and locked, you will be less likely to overlook confirming
the locked status.
Have fun flying Saratoga.
Ron
"Mike Granby" wrote in message
Old December 21st 04, 08:27 PM
john smith
Good advice, thanks Ron.
the locked status.
Old December 21st 04, 09:04 PM
john smith
Mike, make yourself a spreadsheet with the landing weight and all the
V-speeds.
use the formula:
V(?)landing weight = [squart root(Wlanding weight/Wgross weight)] * V?
gross weight
Where W is the weight and
? = best angle, x
best rate, y
glide
stall clean, s
stall dirty, so
Also keep in mind that V-speeds are different when the gear is up and
the gear is down.
Some manuals will give you both the gear up and gear down Vx and Vy
speeds, most do not.
The PA28R-201RT, for example,
From the POH, Section Four, Normal Procedures
Vy = 97 gear up, flaps up
= 79 gear down, flaps up
Vx = 79 gear up, flaps up
= 73 gear down, flaps up
Remember, these are gross weight speeds (approximately 3600 pounds for
the Saratoga, right?).
Old December 21st 04, 09:22 PM
Jim Burns
Rather than resting your hand ON the gear handle, rest it just underneath
it. This will prevent any sudden turbulence from causing you to
accidentally rip the gear handle right out of the panel. Although the
handles in Pipers are quite hefty, Cessnas and others are not.... and that
would REALLY suck!
confirming
the locked status.
Ron
Fulcrum low transition MPG Pechs1 Naval Aviation 0 October 7th 04 03:14 PM
GPS and Beyond: The SatNav Transition for aviation Kevin Horton Home Built 1 September 22nd 04 10:34 PM
Florida Mil Acft Comms Log - Saturday 1 May 2004 AllanStern Military Aviation 0 May 2nd 04 08:49 AM
Mil Acft Comms Log, Florida - Friday 30 April 2004 AllanStern Military Aviation 0 May 1st 04 08:12 AM
Patrick AFB Area Log - Saturday 7 Feb 2004 AllanStern Military Aviation 0 February 8th 04 09:48 AM
