There's oil in them engines
Old January 13th 05, 12:39 AM
Default There's oil in them engines
Hey folks, I am going to ferrying an airplane from Florida to Virginia next
week. This airplane has a Lycoming O-360 and is now using 100 weight oil.
The airplane is going to stay in Virginia for several months.
Question 1:
To the pilots that fly in this, or similar areas, would you recommend
switching to a multiweight oil? I've asked two mechanics, one said that I
should definitely switch the oil and the other said that 100 weight would be
fine and that I would have to just let the engine warm up longer.
Question 2:
If the answer to the above question is to change the oil, should I have it
changed before the trip up from Florida, or wait until I'm here in Virginia?
Question 3:
Where is a good place to buy oil online or somewhere in Virginia? I can't
seem to locate an oil distributor in Virginia that will sell aviation oil by
the case to individuals. I've looked into the usual on-line culprits,
Aircraft Spruce, Chief, etc. They seem to be about the same price.
Question 4:
Okay, this one is only sorta oil related. Should I look into a preheater?
The airplane will be housed in a non-heated hangar. If you think
pre-heating is necessary for the Virginia winter weather, should it be just
a sump heater or should I get the core heater too?
Thank you for your informative inputs.
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 0 December 2nd 04 08:00 AM
Book Review: Converting Auto Engines for Experimental Aircraft , Finch Paul Home Built 0 October 18th 04 11:14 PM
Diesel aircraft engines and are the light jets pushing out the twins? [email protected] Owning 84 October 4th 04 07:09 PM
P-3C Ditches with Four Engines Out, All Survive! Scet Military Aviation 6 September 27th 04 02:09 AM
Accident Statistics: Certified vs. Non-Certified Engines Ron Wanttaja Home Built 23 January 18th 04 06:36 PM
