CO Detectors
Old January 31st 05, 08:38 PM
Kobra
Default CO Detectors
Anyone know if there is any problem in buying a battery operated "home" CO
detector and mounting it under your seat or somewhere inconspicuous? What
is the difference between a "home" unit and an "aviation" unit?
Now before you get crazy and call me cheap...I know that the credit card
pill type is only a couple dollars, but it does not provided an audible
alarm and a problem may go undetected for some time. Any other "aviation"
detector with an audible alarm is near or over 180 smackers. This is in
contrast to a "home" battery operated CO detector that you can buy for 6 to
12 dollars. What is the difference other than one is marketed to aviation
consumers and the other is targeted to home-owners?
Kobra
Old January 31st 05, 09:04 PM
Darrel Toepfer
I've bought a few of the $25+ units from Wal*Mart. Never seen any of the
6 to 12 dollar CO detectors. They fit nicely up over the glove box in
most Cessnas. Up under the seat in a Tri-Pacer... ;-)
Old January 31st 05, 09:10 PM
Dave Butler
There's a lot of what appears to be useful information at http://aeromedix.com
under the description of their "CO Experts Model 2004". Of course, it's not an
unbiased source.
Old January 31st 05, 09:34 PM
Colin W Kingsbury
"Dave Butler" wrote in message
news:1107206122.745358@sj-nntpcache-3...
CO
What
not an
unbiased source.
The gist of it is that the home units are typically set to alarm at levels
(75-100ppm?), even though impairment begins at much lower levels. They also
have a 1-minute or longer sampling frequency so they will not react
immediately to changes as you make them (such as shutting off the heater or
opening a window). Aeromedix claims this is useful because it can allow you
to troubleshoot what is causing the CO infiltration more effectively. As
Dave points out, Aeromedix is not unbiased.
My opinion, which is worth every penny you're paying for it, is that the
Aeromedix detectors are probably quite good, and at $180 are perhaps a wise
idea particularly if you fly up high where there's less O2 to begin with,
but if you're not going to spring for it, you're better off with a Wal-mart
unit than the credit card or especially nothing at all.
-cwk.
Old January 31st 05, 09:49 PM
Darrel Toepfer
Dave Butler wrote:
"home" CO detector and mounting it under your seat or somewhere
inconspicuous? What is the difference between a "home" unit and an
"aviation" unit?
http://aeromedix.com under the description of their "CO Experts Model
2004". Of course, it's not an unbiased source.
http://aeromedix.com/aeromedix/art/co/#electronic
Here's what they say about "home" units...
Old January 31st 05, 10:10 PM
Kobra
Figuring my life was at least worth the price of a headset and that if
I bought something decent it should last for many years, I bought the
industrial grade monitor made by Quest ($295).
An industrial grade monitor also has the ability to do time weighted
averaging and short term exposure and updates once a second. The
averaging capability means you don't have to be continually watching
the instantaneous levels and almost every airplane I have rented has
had detectable levels of CO.
I use the belt clip to attach it to either the seat belt or seat belt
retaining loop (depending on the plane) where I can glance down at it
once in a while.
Jim Pennino
Remove -spam-sux to reply.
Old February 1st 05, 12:56 AM
Carl Orton
I bought one of the Aeromedix units for $99.
Works great (no I don't work for them, own stock, or any of that other
disclaimer stuff).
Very interesting to watch it operate. In the winter, when you typically
don't have any vents open, on climb-out the unit will start chirping at
about 500' AGL. Mine starts chirping at 10 ppm. Gets up to about 55 ppm.
This occurs because, since no vents are open, there is actually a slight
vacuum in the cabin which sucks in exhaust from the tailcone area.
If you crack ANY air source, including from the heater itself (i.e., wrapped
around the muffler), the reading goes to "0" in a minute or two. Any vent
source that will pressurize the cabin will do.
Very sensitive. About the only bad thing (if you want to call it that...) is
that you cannot leave it in the plane all of the time. If it regularly gets
"baked" at temps over 120F (i.e., in the spring/summer months if you leave
it in a sealed-up plane) the sensor life is dramatically shortened.
Carl
"Kobra" wrote in message
to 12 dollars. What is the difference other than one is marketed to
aviation consumers and the other is targeted to home-owners?
Kobra
Old February 1st 05, 02:12 AM
Jon A.
On Mon, 31 Jan 2005 18:56:53 -0600, "Carl Orton"
disclaimer stuff).
You have a leak, get it checked out.
Carl
Kobra
Old February 1st 05, 08:43 PM
Denny
I have a 'leak' and an alarm every time I taxi down wind and the cabin
vents start sucking engine exhaust...
Denny
Old February 2nd 05, 01:38 AM
Jon A.
So I guess you're sucking engine exhaust, too!
Denny
Stryker/C-130 Pics robert arndt Military Aviation 186 October 8th 03 09:18 AM
ADC chip detectors CS_Mike Home Built 2 September 3rd 03 06:26 AM
