Marine Radio using Aviation Antennae
Old July 2nd 03, 01:01 AM
Default Marine Radio using Aviation Antennae
Doug,
Most aircraft antenna's are 1/4 wave length (about 22 inches.) A quarter
wavelength on marine frequencies is approximately 17 and a half inches.
This is out of the range of most handheld matching circuits. My conclusion
is that the answer to your question is no.
http://www.soaridaho.com/Schreder
"Doug" wrote in message
I want to get a handheld marine radio for my amphib Husky. I wouild like
to
plug it in to my aviation outside antennae that I have installed for my
aviation handheld. Will this work? Marine frequencies are
a.. TX 156.025-157.425 MHz
b.. RX 156.025-163.275 MHz
(from the Icom web site).
Old July 2nd 03, 02:41 AM
Buff5200
You could try the Ham radio market. What you are looking for is an
Antenna Tuner
for the 70cm band. What you want is an antenna tuner that can capactively
"shorten" the 22" aircraft antenna and cause it to match the frequencies
that would
normally use a 17" antenna. You might want to look at www.aesham.com.
Wayne Paul wrote:
Doug,
to
Old July 2nd 03, 03:20 AM
Tim Ward
"Buff5200" wrote in message
Antenna Tuner
that would
No. The 70 cm amateur band is around 440 MHz -- way above 160 MHz.
The marine frequencies would be closest to 2 meters, and not all that close.
I think a dedicated antenna is going to be simpler, cheaper, and work
better.
Jim, I believe at one time you posted a pointer to an advisory circular of
best practices for installing non-aviation band radios in aircraft. Maybe
you could dig that out again.
Tim Ward
Old July 3rd 03, 05:37 AM
Buff5200
better.
Sorry, my misprint, I meant a dual band 2M/70cm tuner.
Absolutely, a dedicated antenna is the best move. Unless you are trying
to mount an extra antenna
on a certified aircraft. Lots of paperwork and $$$. I was speaking to
the concept of using a HT marine
radio on an antenna "normally" used for aviation band, and already
installed in the airframe.
Old July 3rd 03, 06:32 AM
Tim Ward
close.
better.
I understood you to mean an antenna tuner.
That's why I mentioned Jim Weir's previous posting of a pointer to an AC
about mounting non-aviation radios in airplanes. I think last time it was
in connection with amateur radio in an airplane, but the principals would be
the same.
Tim Ward
Old July 25th 03, 11:20 AM
Ken Mattsson
While on the subject of antennas, having built a couple of Jimīs plumber
delights, could this antenna design in principle be used for any bands or
can it only be built for center frequencies within the VHF-band? You see, I
have this little cute Yaesu scanner and Iīd love to build a few more
antennas for it, base antennas that is. I already have a set of homemade
portable antennas for it out of bnc connectors with welding rod sticks.
Cheers, Ken
Finland
Old August 5th 03, 05:47 AM
Craig Davidson
Ken Mattsson wrote in message ...
Cheers, Ken
Finland
Every antenna I have seen can be built to any frequency. Do it by adjusting
the dimensions of the antenna inversely proportional to the frequency. for
example if you want the antenna to work at twice the frequency then the
dimensions should be half. Likewise if you want to use the antenna at half
the frequency then the dimensions should be doubled.
Old August 5th 03, 05:22 PM
Jim Weir
That is true...to a crude first approximation. The thickness of the antenna as
a function of frequency and antenna length is not so linear. The actual
calculation goes:
Calculate the THEORETICAL length as a submultiple of the wavelength.
Then do the finagle fatness factor for element thickness.
"Craig Davidson"
-Ken Mattsson wrote in message ...
-While on the subject of antennas, having built a couple of Jimīs plumber
-delights, could this antenna design in principle be used for any bands or
-can it only be built for center frequencies within the VHF-band?
-Cheers, Ken
-Finland
-Every antenna I have seen can be built to any frequency. Do it by adjusting
-the dimensions of the antenna inversely proportional to the frequency. for
-example if you want the antenna to work at twice the frequency then the
-dimensions should be half. Likewise if you want to use the antenna at half
-the frequency then the dimensions should be doubled.
http://www.rst-engr.com
Old August 11th 03, 04:33 PM
Steve Roberts
find a ham radio operator in your area with a VHF capable SWR meter
(or just order a 2 meter swr meter from AES) if the SWR (standing
wave ratio) is greater then 2:1 then the antenna is not well enough
matched for even casual use. A good match is from say 1.1:1 to 1.40:1.
SWR meter hooks between the radio and the antenna and measures
transmitted and reflected power (well , sort of, the real explanation
would take a couple of pages). If the antenna isnt a good transmitter
at a particular frequency, then its a good reflector of RF back down
the cable. That RF has to go somewhere and that somewhere is back
into the final stage of the transmitter, causing heat and maybe
burnout.
Most modern marine HTs are designed with a circuit that backs off the
TX power or shuts down the transmitter if tyou have a bad match.
If this is for use at altitude in a non safety of life application, IE
calling your wife on the boat, you can get away with a crappy swr.
However keep in mind that if you transmit from any reasonable
altitude, your range is increased dramtically, and the marine RADIO is
FM, not AM, and the strongest singal wins on FM, unlike AM whjere they
overlap, so using a a decent marine radio at 5000 feet above San Fran,
you could end up capturing the channel down the whole west coast.
Probably somewhat illegal unless your doing some form of air to ground
work as part of your flying.
if your just gonna receive, the airband antenna will be just fine.
Steve Roberts , N8VKD
Old August 11th 03, 04:45 PM
Jim Weir
Horsefeathers. A 2:1 VSWR transmits 90% of the applied power. A 3:1 VSWR
transmits 75% of the applied power. Have you actually ever MEASURED a
commercial aircraft band antenna from bandedge to bandedge as installed on an
aircraft?
(Steve Roberts)
-find a ham radio operator in your area with a VHF capable SWR meter
-(or just order a 2 meter swr meter from AES) if the SWR (standing
-wave ratio) is greater then 2:1 then the antenna is not well enough
-matched for even casual use.
Swift Boat Veterans For Truth: Are They Going To Sink John Kerry? BUFDRVR Military Aviation 151 September 12th 04 10:59 PM
Lot of noise being made about Purple Hearts Jack Military Aviation 154 September 8th 04 08:24 PM
Associate Publisher Wanted - Aviation & Business Journals Mergatroide General Aviation 1 January 13th 04 09:26 PM
Marine Radio using Aviation Antennae Jim Weir Home Built 13 August 12th 03 11:05 PM
Marine Radio using Aviation Antennae Jim Weir Piloting 0 July 1st 03 08:28 PM
Copyright Đ2004-2025 AviationBanter.
