cobra alum trailer re finish
Old December 25th 11, 04:01 PM posted to rec.aviation.soaring
Cliff Hilty[_2_]
Default cobra alum trailer re finish
Okay we've talked about gliders now lets talk about trailers I have a cobra
1984 all aluminum chalking up needs and needs to be refinished what
would you use and do you need to prime. There is no peeling just severe
chalking the current plan is too sand for a tooth an wipe it down before
applying a one part auto paint. Any other suggestions? I have never
painted before so am open for suggestions.
Thanks
CH
Old December 25th 11, 05:13 PM posted to rec.aviation.soaring
David Martin
I had the same issue on an older fiberglass cobra and solved it by
taking to an auto repair shop. Had to hunt around a bit before I
found one that would take it. They sanded and filled as needed and
then primed and final coat as though was a car repair. Even put it
through their drying/curing hot room. Came out very nice and much
less expense than if I would have done it myself. Suggest looking
into that kind of repair.
ASW27BV
Old December 26th 11, 04:28 AM posted to rec.aviation.soaring
km
On Dec 25, 9:01*am, Cliff Hilty
Thanks
CH
If you have chalking and no peeling you could always do a cut and buff
with rubbing compound and wax. Start with a mild compound and work
your way up if needed. If you do need to paint, take a look at some of
the mail order parts houses such as Summit. They have a limited stock
colors (Which doesn't matter if you are choosing white) and vastly
cheaper prices for single stage paints. Good luck.
Old December 27th 11, 09:00 PM posted to rec.aviation.soaring
Charles Yeates
There is a delightful soaring club just a few kilometers north of Taupo -- a
fine mob & good soaring.
"Cliff Hilty" wrote in message
.com...
cobra
Thanks
CH
looking for used Cobra trailer Brad[_2_] Soaring 3 July 1st 11 02:58 AM
Cheap Cobra Trailer Lights 1998 Trailer on E-bay USA ONLY! flyingmr2 Soaring 4 November 16th 10 02:11 AM
COBRA TRAILER Gordon Schubert[_2_] Soaring 0 February 10th 09 04:15 AM
Cobra Trailer [email protected] Soaring 22 December 7th 06 11:38 PM
FS: Cobra Trailer Ed Byars Soaring 0 September 22nd 03 04:47 PM
