SGS 2-33A Form337 for Radio/Transponder
Old January 2nd 12, 09:57 PM posted to rec.aviation.soaring
T[_2_]
Default SGS 2-33A Form337 for Radio/Transponder
We are looking for any existing Form337 to install a battery driven
electrical system in an SGS 2-33A. We are tucked in close to Class B
airspace that is about to expand in the next year and feel a
transponder would be a great idea in all of our gliders. We've been
using handheld radios for years, but no one has made a handheld
transponder that I can find.
Thanks
T
Old January 2nd 12, 11:15 PM posted to rec.aviation.soaring
Dave Nadler
A handheld transponder would be an extremely bad idea !
Get a TRIG transponder, Mode S.
Put a stub antenna somewhere in the back pointing
down aft of the gear, with ground-plane above and inside.
Use the proper and expensive coax for the antenna;
this is not a radio shack nor shade-tree job.
Really best to get a proper radio shop to do the install.
Can't help you with a 337 but a good radio shop can.
Hope this helps,
Old January 3rd 12, 02:57 AM posted to rec.aviation.soaring
Hope this helps,
The problem is that the "good" radio shop won't want to do install
without having "approved data" to follow.
Schweizer needs to do a modern battery installation drawing for folks
to follow. The existing one is for a lantern battery.
UH
Old January 3rd 12, 03:16 AM posted to rec.aviation.soaring
T[_2_]
Hope this helps,
Just kidding on the handheld, YO.!
We are looking at the Trig units for the fleet, and roger on the
proper coax. We have experience within the club in that area. The
issue is an approved electrical system and battery box for the 2-33.
T
Old January 3rd 12, 06:40 AM posted to rec.aviation.soaring
Hagbard Celine
The Canadian Air Cadets have equipped some of their 2-33's with
transponders and they are real sticklers for doing everything
according to the regulations. Although the installation certification
they got would have been with Transport Canada it would probably be
useful to as a reference when you're trying for FAA approval.
Old January 3rd 12, 03:26 PM posted to rec.aviation.soaring
kirk.stant
The Air Force Academy 2-33s were also equipped with radios. Civil Air
Patrol has some of them now. Perhaps contact them? They were all
civil registered so would have needed FAA paperwork, one assumes.
As opposed to military aircraft, which are not usually certified, or
military pilots, who do not necessarily have certificates!
Good luck!
Kirk
Transponder vs. Portable Transponder Detectors John Murphy Soaring 16 December 20th 08 07:25 AM
Radio & transponder price drop [email protected] Soaring 1 May 27th 06 11:14 PM
Parts for sale Microair radio and Microair transponder User Home Built 2 December 14th 05 11:23 PM
FA OLD AIRCRAFT RADIO TRANSMITTER STANDARD RADIO Ron Restoration 0 October 26th 03 12:02 AM
Recommendation for Radio, transponder and Altimeter Ron Natalie Home Built 0 July 8th 03 03:40 PM
