Excel Worksheet and Chart
Old October 29th 03, 12:09 PM
Paul
Default Excel Worksheet and Chart
I'm currently working at creating an Excel file on my Palm that would allow
me to easily calculate the distances for take off and landing on my 172 for
every situation...
Does anyone of you use this kind of file (with a chart) for the "weight and
balance"? Would it be possible to have a copy or an example of the file that
I could use with my own numbers?
Thank you and good flight to you all
Paul
Old October 29th 03, 12:53 PM
dharakos
This might be a good starting point for you.
http://www.flightclub.com.au/wb/
Regards,
David Harakos
dharakos
Posted via OziPilots Online [ http://www.OziPilotsOnline.com.au ]
- A website for Australian Pilots regardless of when, why, or what they fly -
Old October 29th 03, 04:33 PM
blanche cohen
Unless you're interested in the activity as a learning expeerience,
there are very low-cost programs that this -- check out
the "aviation" topic in handango or other palm-related websites.
Should be about $8-10.
And for W&B, CoPilot by Laurie Davis is probably the most
cost-effective software for palm -- again, check the palm-related
websites.
Old October 29th 03, 04:56 PM
Paul
Thank you David
This is what I need. I will have to "simpliflied it" a lttle bit because of
the capability of the Palm, but it will be perfect.
Thank you again
Paul
"Paul" a écrit dans le message de
allow
for
every situation...
and
that
Paul
Old October 29th 03, 05:00 PM
Paul
Thank you you to,
I used Laurie Davis software since 2-3 years. It's great. But I'm building
up a speadsheet for Takeoff and Landing calculation... after a near crash
Takeoff this summer from a short & windy runway.
Paul
"blanche cohen" a écrit dans le message de
websites.
Old October 29th 03, 07:46 PM
Larry Fransson
every situation...
balance"?
I created an Excel spreadsheet for doing Lear 35 weight & balance on my Palm. It probably functions similarly to what you want in that it does lookup and interpolation for fuel moments. It doesn't do any charting, though. Contact me by e-mail if you're interested.
Larry Fransson
Seattle, WA
Old October 29th 03, 09:54 PM
Sridhar Rajagopal
I have a simple w&b chart in my navlog spreadsheet.
http://www.geocities.com/sridhar007/flying.html - Click on Software,
or Planning . version 4.0
-Sridhar
every situation...
Old October 29th 03, 10:03 PM
Paul
Tjhank you Sridhar,
But your chart is password protected... So I can't check it. (Palm do not
support "XY (Scatter)") chart !
Paul
"Sridhar Rajagopal" a écrit dans le message
de ...
-Sridhar
allow
for
every situation...
and
that
Old October 29th 03, 10:31 PM
blanche cohen
The numbers you really want are on the Type spec for the aircraft. All
of these can be found on the FAA's website. That takes care of the
W&B issues.
For the TO&Landing numbers, you need to "optimum" numbers from the
manufacturer. They should be in the POH for the aircraft. Additionally
the "fudge factors" for various factors (dry grass, wet gradd, slope,
temp, runway length, etc) are either in the POH or supplemental
documentation. If you can't easily find it, check various web
sites such as AOPA Safety Foundation and FAA.
For example, the ASA lists these multiply factors for both the
Cherokees (and Warriors) and the Cessna 172:
Take off
Variation Factor
10% increase in aircraft weight 1.2
Each 1000 ft increase altitude 1.1
Each +10 deg C increase in temp 1.1
Dry, short grass 1.2
Dry, long grass 1.25
Wet, short grass 1.25
Wet, long grass 1.3
Each 2% uphill slope 1.1
Tailwind that's more than 10% of
your lift-off speed 1.2
Landing
Variation Factor
10% increase in aircraft weight 1.1
Each 1000 ft increase altitude 1.05
Each +10 deg C increase in temp 1.05
Dry, long grass 1.3
Wet, short grass 1.3
Wet, long grass 1.4
Each 2% uphill slope 1.2
Consider a Cherokee 180 at altitude of 1500 ft on a 25C day,
flat concrete, no tailwind, weigh of 1700 pounds. Then from the Piper
tables the TO distance is 2200 feet -- on a good day, with a brand new
aircraft and a test pilot. Personally, I'd plan for 3000 or more!
Old October 30th 03, 10:52 PM
Sridhar Rajagopal
!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"
html
head
meta http-equiv="Content-Type" content="text/html;charset=ISO-8859-1"
title/title
/head
body text="#000000" bgcolor="#ffffff"
I've added an unprotected version br
br
a class="moz-txt-link-freetext" href="http://www.geocities.com/sridhar007/flightplan_4_unp.xls"http://www.geocities.com/sridhar007/flightplan_4_unp.xls/abr
br
-Sridharbr
br
Paul wrote:br
blockquote type="cite"
pre wrap=""Tjhank you Sridhar,
Paul
"Sridhar Rajagopal" a class="moz-txt-link-rfc2396E" "<sri >/a a écrit dans le message
de a class="moz-txt-link-freetext" "news:7 /a...
/pre
pre wrap=""I have a simple w&b chart in my navlog spreadsheet.
a class="moz-txt-link-freetext" href="http://www.geocities.com/sridhar007/flying.html"http://www.geocities.com/sridhar007/flying.html/a -> Click on Software,
-Sridhar
Paul wrote:
/pre
pre wrap=""I'm currently working at creating an Excel file on my Palm that would
/pre
/blockquote
/blockquote
pre wrap=""!----allow
/pre
pre wrap=""me to easily calculate the distances for take off and landing on my 172
/pre
/blockquote
/blockquote
pre wrap=""!----for
/pre
pre wrap=""every situation...
/pre
/blockquote
/blockquote
pre wrap=""!----and
/pre
pre wrap=""balance"? Would it be possible to have a copy or an example of the file
/pre
/blockquote
/blockquote
pre wrap=""!----that
/pre
pre wrap=""I could use with my own numbers?
/pre
/blockquote
/blockquote
pre wrap=""!----
/pre
/blockquote
/body
/html
Excel worksheet and chart Paul Owning 2 November 3rd 03 10:42 PM
