ASW-24 Main Wheel Removal
Old March 16th 12, 08:55 PM posted to rec.aviation.soaring
Lauren Rezac
Default ASW-24 Main Wheel Removal
Does anybody know the trick to removing an ASW-24 main wheel. I have
removed the brake caliper and the main wheel bolt. But I cannot get
the main wheel to separate from the main gear trunnion. I talked to
John Murry and he said to remove the aluminum spacer on the left side
of the wheel and then the wheel will come out easily (since the wheel
is keyed in the right side for the brake). I have tried that and I
cannot get just the aluminum spacer to move (it is captured between
the wheel and the trunnion). Any ideas?
Old March 16th 12, 09:30 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
On Mar 16, 12:55*pm, Lauren Rezac wrote:
Does anybody know the trick to removing an ASW-24 main wheel. *I have
removed the brake caliper and the main wheel bolt. *But I cannot get
the main wheel to separate from the main gear trunnion. *I talked to
is keyed in the right side for the brake). *I have tried that and I
the wheel and the trunnion). *Any ideas?
Try applying some lateral forge to the gear legs (spread them apart),
don't be afraid to apply considerable fprce. Your legs may be slightly
bent.
Cood Luck,
JJ
Old March 17th 12, 03:56 AM posted to rec.aviation.soaring
glider LT
bent.
Cood Luck,
JJ
I'd have to look again to get the magic incantations, but you don't have
to apply force to get it out. I've had it off a few times - I had the
spacers backwards for a while. It does require some creative zen moves
though.
Steve
Old March 17th 12, 06:03 AM posted to rec.aviation.soaring
Tom Claffey
Cut the lockwire on the 2 bolts on the brake caliber and seperate caliper
halves rather than removing caliper itself.
Tom
bent.
Cood Luck,
JJ
though.
Steve
Old March 17th 12, 09:31 AM posted to rec.aviation.soaring
Eric
Once the caliper is off and the axle bolt is out, move the wheel
rearwards untill the spacers are clear of the fork. You can then
remove the spacers and move the wheel down.
On Fri, 16 Mar 2012 12:55:28 -0700 (PDT), Lauren Rezac
Old March 19th 12, 05:20 PM posted to rec.aviation.soaring
Lauren Rezac
rearwards untill the spacers are clear of the fork. *You can then
the wheel and the trunnion). *Any ideas?- Hide quoted text -
- Show quoted text -
Thanks for everyone's reply. I found that not only do you need to
remove the calipers, but there in one bolt that hold the caliper plate
to the landing gear trunnion. Once that bolt (and the axle bolt and
the calipers) are removed the wheel is removed relatively easily.
Lauren
Glider Main Wheel Dolly Jim[_18_] Soaring 0 March 9th 11 05:19 PM
main wheel dollies, plans? [email protected] Soaring 1 July 18th 07 07:55 AM
Seeking US Source for Main Wheel Tubes Chris OCallaghan Soaring 7 August 28th 04 04:46 PM
Wheel pants for 6.00 x 6 wheel/tire Wallace Berry Home Built 2 January 23rd 04 05:22 AM
