Basic battery charger question
Old March 17th 12, 01:19 PM posted to rec.aviation.soaring
RS
Default Basic battery charger question
Fairly basic question but wanted to double check before I placed the
order.
I used to have a 12V7AH battery that came with it's own charger when I
bought it. I'm replacing that battery with a 12V9AH that doesn't come
with it's own charger. No problem with using the charger from the old
battery with the new, correct? Both are sealed lead batteries.
Old March 17th 12, 02:48 PM posted to rec.aviation.soaring
Dan Marotta
You are correct. No Problem.
"RS" wrote in message
order.
Old March 17th 12, 03:15 PM posted to rec.aviation.soaring
Dan Marotta
It will take a bit longer to fully charge the larger battery.
"Dan Marotta" wrote in message
order.
Old March 17th 12, 05:25 PM
POPS POPS is offline
Member
First recorded activity by AviationBanter: Dec 2010
Quote:
order.
That would be correct.
Old March 18th 12, 12:45 AM posted to rec.aviation.soaring
RS
On Mar 17, 12:25*pm, POPS wrote:
order.
bought it. *I'm replacing that battery with a 12V9AH that doesn't come
with it's own charger. *No problem with using the charger from the old
battery with the new, correct? *Both are sealed lead batteries.
POPS
Appreciate the help, thanks.
Old March 19th 12, 04:03 AM posted to rec.aviation.soaring
JohnDeRosa
On Mar 17, 6:45*pm, RS wrote:
order.
POPS
Appreciate the help, *thanks.
I would also say, "Yes, should be no problem." But CYA and find the
manual for the charger and make sure there are no gotcha's charging
the larger battery. I doubt it but you never know.
For Sale: 14 volt battery charger Jim[_23_] Soaring 0 August 23rd 09 08:18 PM
Battery Charger [email protected] Soaring 5 February 5th 07 07:41 AM
Basic battery charging question [email protected] Soaring 28 April 10th 06 04:12 PM
RG Battery Charger by Jim Weir in Kitplanes Kevin O'Brien Home Built 4 January 6th 05 02:19 AM
12 Volt DC input Battery Charger Michael I Green Soaring 2 March 15th 04 03:52 AM
