Blanik L13AC value
Old March 21st 12, 07:54 AM posted to rec.aviation.soaring
Ramy
Default Blanik L13AC value
What should be the market value of an L13AC (including trailer), assuming in good shape?
Ramy
Old March 21st 12, 08:55 PM posted to rec.aviation.soaring
Renny[_2_]
Ramy
Ramy,
It all will all depend on the results of the following (from the
Blanik website):
"In May 2011, Aircraft Design and Certification Ltd (AD&C), based in
Germany, submitted an application for a Supplemental Type Certificate
(STC) to the FAA, Small Airplane Directorate for approval of their
inspection and modification program for the L-13 BLANÍK sailplane.
The intent of this STC is to modify the existing wing attachment
structure as an AMOC to AD 2010-18-05 and reinstate flight operations
of the L-13 BLANÍK sailplane."
If this STC is approved the question will be what will be the cost to
make the STC modifications and then get the L-13s flying again. Once
you know that "number," you may be able to come up with a market
value...
Now, at the SSA Convention I heard some "numbers" thrown around on the
possible cost of implementing the STC, but I am really not sure if any
"real" numbers are available for you to use. I did "hear" that it
might be anything from $15K to 25K, or even more, but that important
number is still TBD...
Thx - Renny
Old March 21st 12, 09:05 PM posted to rec.aviation.soaring
Tony[_5_]
The "Blanik AD" does not apply to the L-13AC.
http://sites.google.com/site/blanikspar/
Old March 21st 12, 09:13 PM posted to rec.aviation.soaring
Hagbard Celine
I would think it would be fairly close in value to an L-23 of
comparable age/time/condition/equipment. It would probably go for a
little more due to the increased aerobatic capability. Look for L-23
ads on sites like Wings&Wheels and search back a year or two using
archive.org's Wayback Machine to get a larger sample. If you're lucky
you might even find a few actual L-13AC's for sale even though they
seem to be much less common than L-23's.
Old March 21st 12, 10:01 PM posted to rec.aviation.soaring
Renny[_2_]
My mistake...My apologies...
Thanks - Renny
Old March 21st 12, 10:02 PM posted to rec.aviation.soaring
Renny[_2_]
My mistake and my apologies for the error........
Thanks - Renny
Blanik L23 AD tomcatvf51 Soaring 1 January 27th 11 01:17 AM
Blanik L-23 Super Blanik Manual -F.C.F.S. Joel Flamenbaum Soaring 2 April 14th 10 04:29 PM
Blanik L23 AD tomcatvf51 Soaring 0 February 12th 09 01:52 PM
Blanik L-23 BDS[_2_] Soaring 7 June 27th 07 04:35 PM
Blanik L-13 brien Soaring 0 December 5th 04 03:00 PM
