Cobra Top Hinge Bolt Failure - Revisit
Old April 23rd 12, 12:41 PM posted to rec.aviation.soaring
Whiskey Delta
Default Cobra Top Hinge Bolt Failure - Revisit
Any further information or new developments regarding the bolt failure
discussed last year? Discussion found he
http://groups.google.com/group/rec.a...b46ee572ef6bb6
WD
Old April 23rd 12, 07:09 PM posted to rec.aviation.soaring
Steve Koerner
WD: The writeup I did on my solution seems to have passed muster at
the factory as I have learned that some folks have been referred to it
by Cobra. Here's the link again: http://www.box.net/shared/9dvnt7qgs8
Steve Koerner
www.wingrigger.com
Old April 23rd 12, 11:34 PM posted to rec.aviation.soaring
Andrzej Kobus
On Apr 23, 2:09*pm, Steve Koerner wrote:
WD: *The writeup I did on my solution seems to have passed muster at
by Cobra. *Here's the link again:http://www.box.net/shared/9dvnt7qgs8
Steve Koernerwww.wingrigger.com
Are you making these backing plates for sale or is the factory going
to create a modification kit, asking just in case?
Old April 24th 12, 03:52 AM posted to rec.aviation.soaring
Dave Nadler
Steve Koerner
www.wingrigger.com
The backing plate does not really help, as there are reinforcement
inserts in the top where the bolts go through, but not in the broader
area under the handle.
Distortion of the corners of the trailer is a separate problem from
the bolts. I sketched a solution that Alfred said he would build;
this reminded me I hadn't received the parts and I just sent Alfred
and Ralf an email. I've been a wee bit busy, sorry this hasn't
gotten completely sorted yet...
Hope this helps,
Old April 24th 12, 07:05 AM posted to rec.aviation.soaring
Steve Koerner
Steve Koerner
www.wingrigger.com
So a backing plate that distributes the load over an area that is
around ten times greater than the area under the original handle does
not really help. That's a pretty interesting conclusion, Dave. I'm
glad you have this all sorted out for them now.
Old April 24th 12, 12:25 PM posted to rec.aviation.soaring
Dave Nadler
Steve Koerner
www.wingrigger.com
The area where the bolts goes through has a solid material between
the inner and outer laminates; other than that its just the expanding
core material they use (no compressive strength). Spindelberger
told me it does not help to add a backing plate because of this...
Hope that is clear,
Best Regards, Dave
Old April 24th 12, 03:08 PM posted to rec.aviation.soaring
Andy[_1_]
Hope that is clear,
Best Regards, Dave
Dave,
My trailer has not such reinforcing inserts. In fact I proposed
introducing such inserts as the permanent fix. Only the handles
themselves have hard inserts.
If there were inserts the outer shell would not have collapsed toward
the inner shell causing the bolt tension to be eliminated. I have
photos of the severe deformation of the outer shell under the handles
of my trailer.
In my opinion the insert fix would be far superior to the backing
plate solution but it fell on stony ground.
Andy
Old April 24th 12, 04:26 PM posted to rec.aviation.soaring
Steve Koerner
The structure immediately under the handles had clearly collapsed.
There is no such solid material between the inner and outer laminate
on mine.
The backing plate has resolved the problem quite well.
Old April 25th 12, 11:21 PM posted to rec.aviation.soaring
on mine.
I've looked at my hinge bolts a number of times, but can't detect any problems. Are there any symptoms that precede bolt failure, i.e. loose handles?
TIA,
Frank (TA)
Old April 26th 12, 05:50 AM posted to rec.aviation.soaring
Ian Reekie
on mine.
handles?
TIA,
Frank (TA)
We checked all the Glass fibre top (twin skin) Cobra trailers at our site.
(over 10 older trailers ) None had so far suffered a hinge failure.
The most obvious sign of a potential problem is loose bolts which are
easily tightened. One older trailer had a couple of mm slack that could be
tightened out.
I changed the bolts on mine for longer stronger bolts (12.9 spec) that do
not have the thread section across a load bearing junction.
I noticed a lot of corrosion present on the bolts removed from my 13 year
old trailer stored in a English climate. It might be prudent to replace
them after about 10 years depending on local conditions.
I refitted with a aluminium backing plate for good measure but it probably
is not necessary as all the compression between the twin skins seems to
have taken place.
Cobra top hinge plate bolt failure Andy[_1_] Soaring 43 May 24th 11 03:41 AM
Cobra top hinge plate bolt failure Steve Koerner Soaring 19 May 22nd 11 03:30 PM
Cobra top hinge plate bolt failure JJ Sinclair[_2_] Soaring 0 May 18th 11 07:45 PM
Cobra top hinge plate bolt failure Andy[_1_] Soaring 0 May 17th 11 12:01 AM
Cobra bottle jack failure db_sonic Soaring 15 October 30th 09 03:34 PM
