I just tried my new unit today. It seemed to be working fine but when
I uploaded the flight to the SD card it was "busy" for a long time then shutoff and It won't turn back on. Anybody with any experience on these new units?? Rick |
On Sunday, April 29, 2012 3:27:56 PM UTC-7, Rick wrote:
I just tried my new unit today. It seemed to be working fine but when I uploaded the flight to the SD card it was "busy" for a long time then shutoff and It won't turn back on. Anybody with any experience on these new units?? Rick You might have a faulty unit. Mine works perfectly. Depending on the length of flight, the copy may take a few seconds to maybe up to a minute (for a 6 hour flight at 1 sec sampling). Dumb question, but could it have run out of battery? |
On Apr 29, 6:27*pm, Rick wrote:
I just tried my new unit today. It seemed to be working fine but when I uploaded the flight to the SD card it was "busy" for a long time then shutoff and It won't turn back on. Anybody with any experience on these new units?? Rick My Colibri II took a few tries to recognize the factory MiroSD card. Wouldn't turn on. Tried pulling the card out, still would not turn on. Plugged it in for a while, still no. Let it sit for several hours off the charger then it worked. I think flight recorders are sensitive to change. Our club has an EWMicrorecorder that exhibits this type of behavior. I think it requires the SD card be formatted FAT, not FAT32. Since then I only use factory issued memory cards. Try putting the card back in if that was the state it was last time it was used. Let it sit a few hours and try. ....Aaron |
On Apr 29, 3:27*pm, Rick wrote:
I just tried my new unit today. It seemed to be working fine but when I uploaded the flight to the SD card it was "busy" for a long time then shutoff and It won't turn back on. Anybody with any experience on these new units?? Rick From the Manual Colibri II SD card reader The unit has an integral micro SD card reader positioned on the left side of the unit. SD card is used for: -Uploading TP (CUP format) -Downloading flights from internal memory (IGC format) -Uploading of flight declaration in LX format (.HDR ) Note! Flight data is stored into internal memory, so SD card is not required to be inserted during flight. Flight options Pressing enter on any flight of the logbook will enable Copy to SD and View Info function. Copy to SD will copy flight of interest to SD card. View Info will show pilot and glider data. SD Card SD card is a data transfer medium which makes possible to arrange input of data (turn points, flight info) and to export flight data which are stored in flight recorder. The flights are written to the card in .IGC format that means immediately ready for flight evaluation. LOAD TP: Transfers turn point data from SD to device. Pressing enter button will show list of all *.cup formatted files in LX/TP directory. Select file of interest and start transfer with enter. LOAD INFO: Transfers header files from uSD to device. Pressing enter button will show list of all *.hdr formatted files in LX/FLINFO directory. Select file from which you wish to transfer declaration header. SD INIT: Creates all needed directories on SD card. (LX/TP, LX/FLINFO, LX/FLIGHTS) Important! If TP file has more than 500 points only first 500 will be transferred, rest will be cut off. Notice the line that says important! Richard www.craggyaero.com |
On Monday, April 30, 2012 3:52:59 PM UTC-4, akiley wrote:
On Apr 29, 6:27*pm, Rick wrote: I just tried my new unit today. It seemed to be working fine but when I uploaded the flight to the SD card it was "busy" for a long time then shutoff and It won't turn back on. Anybody with any experience on these new units?? Rick My Colibri II took a few tries to recognize the factory MiroSD card. Wouldn't turn on. Tried pulling the card out, still would not turn on. Plugged it in for a while, still no. Let it sit for several hours off the charger then it worked. I think flight recorders are sensitive to change. Our club has an EWMicrorecorder that exhibits this type of behavior. I think it requires the SD card be formatted FAT, not FAT32. Since then I only use factory issued memory cards. Try putting the card back in if that was the state it was last time it was used. Let it sit a few hours and try. ...Aaron Not sure if my problem was the same as yours but after trying to recharge by outlet and USB it still wouldn't work. Packing it up to return and gave it one last try and poof it turns on. Then try transfer of flt log to SD card which took several (10-15) minutes when the unit quit this time it took seconds. Seems to be working OK will check Vario and thermal helper functions when I fly. Thanks for all the help and suggestions. rick |
On May 2, 9:13*pm, Rick wrote:
On Monday, April 30, 2012 3:52:59 PM UTC-4, akiley wrote: On Apr 29, 6:27*pm, Rick wrote: I just tried my new unit today. It seemed to be working fine but when I uploaded the flight to the SD card it was "busy" for a long time then shutoff and It won't turn back on. Anybody with any experience on these new units?? Rick My Colibri II took a few tries to recognize the factory MiroSD card. Wouldn't turn on. *Tried pulling the card out, still would not turn on. *Plugged it in for a while, still no. *Let it sit for several hours off the charger then it worked. * *I think flight recorders are sensitive to change. *Our club has an EWMicrorecorder that exhibits this type of behavior. *I think it requires the SD card be formatted FAT, not FAT32. *Since then I only use factory issued memory cards. Try putting the card back in if that was the state it was last time it was used. *Let it sit a few hours and try. ...Aaron Not sure if my problem was the same as yours but after trying to recharge by outlet and USB it still wouldn't work. Packing it up to return and gave it one last try and poof it turns on. Then try transfer of flt log to SD card which took several (10-15) minutes when the unit quit this time it took seconds. Seems to be working OK will check Vario and thermal helper functions when I fly. Thanks for all the help and suggestions. rick Glad you got it going. After things calmed down mine has acted 100% normal. I think this is a great little unit. My first test flight was the worlds slowest silver distance and it worked perfectly for a four plus hours. I belong to a club, so I bought a 4" long Batteries Plus, 12v (1lb) to power it in the Cirrus we have. I really like the large relative wing arrow on the display. Will be great for ridge flights. .... Aaron |
| Thread Tools | |
| Display Modes | |
| colibri | ryanglover1969 | Soaring | 2 | August 17th 09 01:44 AM |
| Colibri | Fred Blair | Soaring | 2 | August 25th 08 04:24 PM |
| FS Colibri | Ed Hollestelle | Soaring | 1 | December 20th 06 04:00 AM |
| FS Colibri | [email protected] | Soaring | 0 | March 1st 06 01:26 PM |
| Colibri Failures. | Stan Kochanowski | Soaring | 2 | April 6th 05 02:00 PM |
