DG1000S - Weight and Balance work sheet
Old May 24th 12, 08:39 PM posted to rec.aviation.soaring
Default DG1000S - Weight and Balance work sheet
We will soon be flying our DG1000S. Since many pilots will be flying we will need to have a standardized process for determining the correct tail ballast or front ballast. Does anyone have a work sheet for the DG1000 W&B?
Thanks
Phil
Old May 24th 12, 09:21 PM posted to rec.aviation.soaring
Morgan[_2_]
Phil there are a couple suggestions I could make. I don't have a worksheet for a 1000, but it is relatively simple to make one.
Option A if you have a computer at your club that everyone can access, get SeeG from Matt Heron over at http://www.glideplan.com/. It's pretty slick and easy to use and doesn't require much work to set it up.
Option B: The old tried and true spreadsheet. If you use a Google Doc spreadsheet, you can open it up on the web to anyone for editing.
Option C: Tweak the form and javascript off of our W&B for a 2-33. A bit more technical skill required to alter this, but if you have a hosting location it will give you a shared access point for a quick weight and balance calc.
http://www.soaravenal.com/WnB1.htm
Option D: Paper calcs. Last I heard, paper and pencil still worked for figuring out CG although I think the last time I did that was on my check ride.
Lot's of options once you have the moments to work from.
Morgan
Thanks
Phil
ASK-21 Weight and Balance Carl Baxter Soaring 4 June 2nd 11 03:57 PM
PA-32 Weight and Balance John Doe Owning 14 May 23rd 06 02:03 AM
L23 weight and balance Tony Verhulst Soaring 5 December 31st 05 02:54 AM
Weight & Balance DVD jon Home Built 0 October 8th 05 06:39 PM
Weight and balance.. Bart Rotorcraft 9 August 19th 03 03:57 AM
