Golf cart as a tug...
Old June 24th 12, 06:14 AM posted to rec.aviation.soaring
Bastoune
Default Golf cart as a tug...
Is there a difference between gas and an electric golf carts to tow gliders on the ground at a grass strip? (fuel and electricity are both available)? What would be the prefered motorisation if one was looking to get a used one for a club? Would an electric golf cart batteries last an afternoon at the field (assuming new batteries)? Thanks!
Old June 24th 12, 09:58 AM posted to rec.aviation.soaring
Peter Higgs
Hi Bastoune, I would go for the petrol option as you can soon re-fill the
tank dependant upon how much use it gets.
They will tow twin seaters quite easily on tarmac.
However if the glider is leaving ruts in soft ground, they struggle a lot.
This would use a lot of battery, in an electric cart.
The usual limiting factor is wheel grip, as the wheels will spin on damp
grass, due to the light weight on the rear tyres.
Pete
glider=
available)=
used
at
Old June 24th 12, 04:07 PM posted to rec.aviation.soaring
My Club has used both types. Power is about the same. We only use gas now because of the cost and maintenance required for the battery's. They are great when new but in a club enviroment the battery's don't last and the cost to replace them is substantial.
Old June 24th 12, 04:11 PM posted to rec.aviation.soaring
I chose gas (Club Car). I didn't want to have batteries quit while out on the field. I also had some work done on the clutch to gear it down lower.
Old June 24th 12, 05:03 PM posted to rec.aviation.soaring
I've been in four or five clubs and commercial operations that have used both. The electric carts seemed to have better speeds for towing gliders with a wing walker -- that is, they could tow at about the same speed as the ground crew. With gas I was on the throttle, back off, back on, etc., just to stay slow enough to avoid running away from the wing walker. Perhaps you could gear the cart down and avoid this.
I will admit that batteries are an expense and they have to be kept up. But at my last operation (commercial) the line crew were given the responsibility of tending to batteries on a regular basis and we got good results from the batteries -- two years or more operation on an almost daily basis, running out and back to the line (about half a mile each way) numerous times, and towing half a dozen or more gliders out and back. We had battery problems very rarely as long as the ground crew tended to water levels, corrosion prevention and charging on a regular basis.
Old June 24th 12, 05:53 PM posted to rec.aviation.soaring
sisu1a
Electric carts are great, so long as it's one with modern speed
control as they get about double the mileage/charge and work better at
low speeds. EZ Go carts made the switch in 1986, so 1987 or newer are
worthwhile but older than 86 are not. Charge lasts all day, sometimes
all weekend without recharging...
-Paul
Old June 24th 12, 07:55 PM posted to rec.aviation.soaring
AGL
Our club has both gas carts and an electric cart. The electric is
used mainly to transfer disabled passengers and pilots into the
gliders. http://www.freedomswings.ca/images/i...s/ff-hoist.pdf
The advantage of electric is excellent speed and position control.
Would you back up a gas cart with a passenger in a hoist to your
gliders? The centrifugal or snowmobile V-pulley systems are abrupt on
our gas carts, and I don't know how fast you walk your wing when your
plane is being towed by a cart, but they seem to go either too fast or
slow, and taking up slack on the tow rope requires consumate skill.
With an electric, with a modern controller, such as a Curtis, it's
easy. The series-wound electric has maximum torque at zero RPM, so
pulling any of the gliders isn't a problem.
I believe that the battery "issues" are based on people's experience
using obsolete technology for chargers. We use a
http://batterytender.com/electrical-...8v-at-10a.html
It's bolted right to the cart so it can be plugged in anywhere. All
you have to do is plug it in and forget it. It won't overcharge and
takes care of everything. I'm guessing it quadruples battery life.
I'll leave it for other club members to correct me, but the batteries
in the cart were 1 years old when the hoist conversion took place, and
3 years later they are still ok. I check the water in the spring and
fall, and it hasn't been a problem. We leave it plugged in all
winter, and anyone can plug it in at the end of the day. There's a
"gas guage" on the dash.
Having said that, if my plane is on the flight line and I have
forgotten my small brim hat or GPS bluetooth mouse in my car, I grab a
gas cart because they are faster, but that's our carts specifically,
not because it's electric or not.
Old June 25th 12, 01:50 AM posted to rec.aviation.soaring
Bart[_4_]
On Jun 23, 9:14*pm, Bastoune wrote:
*Would an electric golf cart batteries last an afternoon at the field (assuming new batteries)? Thanks!
They do for us. As a matter of fact, I do not think we ever depleted
the batteries below 75% in one day. That's assuming that the built-in
battery level indicator can be trusted.
But, we have a hard dirt runway. We'd use more battery juice on grass.
Also, most of the time we are in a position to launch from where a
glider stopped after landing. YMMV.
The only gas-powered tow vehicle I drove (it was a quad, not a golf
cart) was very difficult to drive slow.
Bart
Old June 25th 12, 03:54 AM posted to rec.aviation.soaring
howdy
However if the glider is leaving ruts in soft ground, they struggle a lot..
Pete
Tarmac – A common but inaccurate term often referring to the paved areas of airports where aircraft park. Usually referring to the airport ramp or “apron” near the terminals, hangars or FBO’s. The vast majority of aircraft operating areas are however constructed of concrete, not “tarmac”. The Wick Airport at Wick in Caithness, Scotland is one of the few airports that still has a real tarmac runway.
In July 26, 1904, Hooley, E. Purnell received U.S. Patent 765,975 for the “Apparatus for the preparation of tar macadam” which involves involved mechanically mixing tar and aggregate (crushed stone or gravel) prior to lay-down, and then compacting the mixture with a steam roller. The tar was modified with the addition of small amounts of Portland cement, resin and pitch.
As petroleum production increased in the mid 20th century, the by-product of refining process, asphalt became available in huge quantities and largely supplanted the use of tar due to its reduced temperature sensitivity. The Macadam construction process also became quickly obsolete due to its high manual labor requirement.
Old June 25th 12, 02:33 PM posted to rec.aviation.soaring
Ian Gutsel
we use a pawnee 235 as a golf cart can not go fast enough to get airbourne
Golden Age Of Aviaiton Baggage Cart... Canuck[_2_] Aviation Photos 0 September 2nd 08 05:48 PM
Golf Cart Tugs Ashton Owning 1 September 3rd 04 03:51 PM
Golf Cart Tugs Ashton Owning 20 August 19th 04 07:19 PM
Golf Cart Tugs Ashton Owning 0 August 12th 04 04:08 PM
Golf Cart Tugs Ashton Piloting 0 August 12th 04 04:03 PM
