Followup -- Rudder Cable Sleeve
Old June 24th 12, 08:11 PM posted to rec.aviation.soaring
Michael J.
Default Followup -- Rudder Cable Sleeve
JJ, T .... Thanks for the advice on how to return the nylon sleeve to its proper position in the "S" tube.
JJ ... after spending an hour using sheer muscle and determination I was able to correct the left rudder. Next morning I tried the heating approach you suggested on the right side without much luck. Being a retired engineer I finally stepped back, looked at things carefully, and decided to use a stainless steel 1/8" cable clamp fastened up against the sleeve and pulled the cable from the forward end. Still a lot of muscle, but worked great. Pretty much what you suggested in your latest post. Closely examined the cables and saw no damage or fraying.
Since I never change the range adjustment on the rudder pedals I'm guessing this problem existed when I first bought the glider and just didn't know enough to recognize it. Thanks again.
Mike J.
Rudder Cable Systems Used in Modern Sailplanes JJ Sinclair[_2_] Soaring 20 May 18th 12 01:57 AM
Rudder cable slots Ernest Christley Home Built 5 July 1st 06 05:29 AM
nicopress sleeve for stainless steel cable ls Home Built 3 December 6th 05 05:09 PM
rudder cable question Bob Loer Home Built 7 November 26th 03 09:34 AM
Rudder cable - was The Little Wheel in Back BD5ER Home Built 9 September 11th 03 05:14 PM
