Signal Transmission of Wi-Fi IP Camera
Old July 6th 12, 11:50 AM
securitycamera2000 securitycamera2000 is offline
Banned
First recorded activity by AviationBanter: Nov 2011
Default Signal Transmission of Wi-Fi IP Camera
A ,CCTV Monitorswifi IP camera is used differently than a wireless camera and has different capabilities. The letters IP represent internet protocol. Representing the signal is transmitted over the internet with a certain protocol. An IP optical device transmits to a router or is connected to the internet by an Ethernet cable connection. This creates the ability to capture a specific area and view the area at a distant place. Differently than a wireless camera that is used within the home to create a system that is portable in nature and viewed on various monitors including the television.
The transmission frequency of a Wi-Fi IP camera is 802.11GHZ. The signal is transmitted to a router or connected to the internet by an Ethernet cable. The IP connection is often referred to as a WIFI connection. A higher signal transmission speed creates a high quality video. A wireless camera transmits to a receiver within a specified distance usually 300 feet and transmits its signal commonly at 2.4GHZ or 5.8GHZ. Many home appliances such as microwaves and land line telephones transmit at these lower frequencies creating occasional interference.
Old July 6th 12, 06:32 PM posted to rec.aviation.homebuilt
Steve Hix[_2_]
Riiiiiiiiiiiiiiiiiiiiiiight.
The signal
But you said above... Which is it?
Never mind.
radio transmission trouble SD[_2_] Soaring 9 October 15th 09 08:40 AM
troubleshooting com's transmission jan olieslagers[_2_] Home Built 2 April 13th 09 03:39 AM
Camera mounts for small digital camera kestrel254 Soaring 5 August 19th 08 05:03 PM
Subaru flywheel pto without transmission [email protected] Home Built 2 November 26th 05 09:00 AM
Transmission design? Otto Gyro Rotorcraft 1 November 7th 03 05:41 PM
