SeeYou Recoder - an Android app for glider pilots
Old July 6th 12, 05:00 PM posted to rec.aviation.soaring
Default SeeYou Recoder - an Android app for glider pilots
Folks: Naviter's first Android app is published in the Google Play store. With a similar iOS app to follow immediately after Apple approves it.
It's an IGC flight file recorder and its name is SeeYou Recorder. It's free. And it's actually an IGC flight recorder on steroids.
http://www.naviter.si/content/view/160/1/lang,en/
Enjoy!
Andrej Kolar
glider pilots use
http://www.Naviter.com/
Old July 6th 12, 06:31 PM posted to rec.aviation.soaring
I'm looking forward to the release of the iOS version for my iPhone. Please continue to develope a full version of SeeYou or as near as possible for iOS. The displays are great in the sun and most people already own one.
Old July 6th 12, 07:22 PM posted to rec.aviation.soaring
kammeyer
Check out GlidePath:
http://itunes.apple.com/us/app/glide...383714417?mt=8
It will record your flight and submit to OLC directly from your phone.
Dave Kammeyer
XLT
Old July 6th 12, 07:49 PM posted to rec.aviation.soaring
I already use Glidepath. It works great as a recorder and for uploading to OLC. I'm looking for a full function Glide computer or as full of functions as possible for the iPhone. I use Glider GPS for the iPhone currently but it doesnt even compare to SeeYou. I'd love to support a company that provides great products already.
Old July 6th 12, 09:50 PM posted to rec.aviation.soaring
WAVEGURU
Many of us have tried glide path here in Oregon, and it is not good at all. It stops in the middle of most recordings, and we can't figure out why it stopped most of the time. And when it stops, none of the flight is saved. I'm really hoping this new app is dependable. I have an Oudie and I like it, but I wish it would color the trace like SeeYou does on the PC. Will this app be able to color the track for vertical speed, or other choices? Now if we could just see the Iphone screen in daylight you might have something?
Boggs
Old July 6th 12, 10:30 PM posted to rec.aviation.soaring
We have logged hundreds of hours of tracks during testing (mostly driving, but lots of flying too) and there was never a reliability issue. Even if your phone fails everything is stored and available for sharing after the phone recovers. No problem there. We already know how to handle these things from SeeYou Mobile and Oudie.
No. Not SeeYou Recorder. It is and it will remain just a friendly free recorder.
See the Roadmap he
Cheers,
Andrej Kolar
glider pilots use
On Friday, July 6, 2012 9:50:51 PM UTC+2, Waveguru wrote:
Many of us have tried glide path here in Oregon, and it is not good at all. It stops in the middle of most recordings, and we can't figure out why it stopped most of the time. And when it stops, none of the flight is saved.. I'm really hoping this new app is dependable. I have an Oudie and I like it, but I wish it would color the trace like SeeYou does on the PC. Will this app be able to color the track for vertical speed, or other choices? Now if we could just see the Iphone screen in daylight you might have something?
Boggs
Old July 10th 12, 04:59 PM posted to rec.aviation.soaring
Ernst
Same experience than Waveguru, Glide Path is not reliable. Look forward to see the Naviter apps.
Ernst
Old July 11th 12, 08:16 PM posted to rec.aviation.soaring
JohnDeRosa
I was speaking to a fellow glider pilot on Saturday about GlidePath.
He reported that it fails "above 3,000 feet".
I found a couple of sites that talk about the issue.
http://ipadpilotnews.com/2012/01/top-12-ipad-tips/
http://www.flyertalk.com/forum/archive/t-1027596.html
http://www.tuaw.com/2009/09/12/unhap...nd-each-other/
Other comments;
1) Iphone uses "assisted" GPS that uses cell towers to get a quick fix
while the regular GPS is busy finding satellites. Then after regular
GPS has its satellites you will get more accurate results.
Ultimately, GPS should work fine without cellular, you just have to
wait longer.
2) That GPS is turned off when in airplane mode. I assume that you
had your phone not in airplane mode and that it worked fine initially,
and then failed after getting higher than the cellular signal. If you
waited long enough, wouldn't the GPS take over? Maybe it is the
cellular service going in/out of range that is causing the iPhone to
bounce back/forth between cellular tiangulation and
3) Cell towers have their antennas pointed slightly downward to
provide optimum terrestrial coverage - so cellular coverage in the air
is always dicey. I always wondered how the 9-1-1 passengers were able
to make their last desperate calls while in the air.
4) Sportys says "But the on-board iPad GPS was made for ground use,
and it’s not very reliable in the air. It has a tendency to drop
offline, especially when switching between apps. For this reason, most
iPad pilots—even those with a 3G iPad—opt for an external GPS. They
are extremely accurate (WAAS-enabled) and very reliable." Sportys has
both plug in and bluetooth add on GPS receivers for $100.
5) http://www.aviationconsumer.com/ has more comments but you have to
subscribe for $36/year.
Small glider logbook for Android phones Tiny Titles Soaring 0 July 28th 11 09:34 PM
Glider and tow pilots wanted Brian[_6_] Soaring 12 March 19th 08 05:47 PM
The best Glider Pilots in the world Valerie Alexander Soaring 0 January 11th 08 09:21 PM
Can we be more than Glider Pilots…? Green Pilot Soaring 0 November 8th 05 08:43 PM
Can we be more than Glider Pilots…? Green Pilot Soaring 0 November 8th 05 08:15 PM
