WGC 2012 Day 5 18m Task?
Old August 10th 12, 04:11 AM posted to rec.aviation.soaring
rlovinggood
Default WGC 2012 Day 5 18m Task?
The graphic for the 18m task for Day 5 shows an overlap between points 66 and 67. Is that okay because they have to fly to point 31 that comes between 67 and 66?
Ray
Old August 10th 12, 05:11 AM posted to rec.aviation.soaring
Tom Kelley
Ray
Go to Soaring spot dot com. It shows a better picture of the task. I believe the scale is just off on the WGC page due to compression.
Regards, #711
Old August 10th 12, 08:43 AM posted to rec.aviation.soaring
Peter Purdie[_3_]
Ray answered his own question. On an area task you visit each area in
turn.
There's nothing in principle to stop the same area being used twice on a
task, although it might look a bit confusing. Certainly nothing to stop an
overlap between areas that are not one after the other.
66
between 67 and 66?
Ray
Regards, #711
Circle Task Chris Soaring 3 December 21st 11 06:35 AM
Task Building Uncle Fuzzy Soaring 5 August 5th 09 09:09 PM
How to be a Task-setter / CD noel.wade Soaring 5 September 27th 08 03:00 AM
New DMSt task: 4 TPs Klaus T. Soaring 0 January 9th 06 01:03 AM
New Task JJ Sinclair Soaring 5 October 23rd 03 02:36 AM
