Replacing position light bulbs
Old December 29th 03, 07:43 AM
Mutts
Default Replacing position light bulbs
Any rental pilot/flying club types out there carrying spare postion
light bulbs with them? Do you have to be an A&P to change them? Do
owners frown on replacing bulbs without being informed first?
How hard is it to change them on Archers and 172s?
Its getting old finding the lights burned out during preflight and
everything is closed.
Old December 29th 03, 07:53 AM
Troy Towner
Two words... Preventative maintenance.
-Blue skies and a tail wind
"Mutts" wrote in message
Old December 29th 03, 08:20 AM
Peter Duniho
No, you don't have to be an A&P. I don't have an airplane on leaseback, but
if I did, I would expect that a renting pilot would either get the FBO/club
mechanic to change the bulb if the airplane was home, or change it
themselves if the airplane was not and lights were required for their
flight.
In other words, I'd prefer that renting pilots not change bulbs (or do other
preventative maintenance that involves removing airplane parts) but
realistically, most renting pilots are entirely competent to handle the task
and would certainly be expected to do so if the task was required for safe
and legal flight.
Never changed them on either of those types, but on my own plane, it's no
harder than changing the tail light, signal, etc. bulb on a car. Usually
just a couple of screws to remove for the lens, and the bulb pops right out.
The hard part is finding the right bulb. Landing and taxi lights are
slightly harder, but still within most folks abilities.
Now, all that said, if you are frequently finding the bulbs burned out, you
may want to rethink who you're renting airplanes from, or at least suggest
to the airplane owners/operators that there might be something causing the
bulbs to fail prematurely. I've owned my airplane for nearly ten years now,
and have only had to replace two bulbs, both of them nav lights.
Pete
Old December 29th 03, 09:09 AM
Dale
If you do change the wingtip bulbs take care. The glass lens used is
easily dropped as you remove the retainer and is expensive to replace.
Been there, done that. G
Dale L. Falk
There is nothing - absolutely nothing - half so much worth doing
as simply messing around with airplanes.
http://home.gci.net/~sncdfalk/flying.html
Old December 29th 03, 03:23 PM
Mark Astley
Mutts:
- You do not have to be an A&P to change bulbs. See FAR 43.3(g) and FAR 43
Appendix A.
- Renting: tell the FBO to change it, it's their job (i.e. your rental price
includes "maintenance"). If you're away from home and you need the light to
be legal, most FBOs will let you have the work done if you call and consult
with them first. In any case, they will most certainly require that an A&P
do the work.
- Flying Club: every club is different but most have a specific maintenance
policy spelled out in their charter.
- Is it difficult? Not really, but with older planes you're more likely to
find rusted out/stripped screws, etc. This is why you should make the FBO
or some other "pro" do it as they'll have the tools on hand. Otherwise, add
a drill and some spare screws to your flight bag. If you're flying
something less than ten years old then disregard.
cheers,
mark
Old December 29th 03, 04:05 PM
Ron Natalie
"Mutts" wrote in message ...
The bulbs are trivial to replace and is an owner/pilot permitted maintenance.
While your skirting legality doing it in a rental, if I had the bulb I would certainly
not hesitate to do it if it meant having to otherwise cancel a night or IFR flight.
Old December 29th 03, 05:01 PM
Peter Duniho
"G.R. Patterson III" wrote in message
Which can be done by the owner, not a renter.
It can also be done by the renter, as long as the renter only works on the
airplane being operated by him (which is the scenario in question here).
If the airplane is used for Part 135 service, the renter is technically not
allowed to. However, if I were that renter, and I couldn't find an approved
mechanic to do the work, I would still do it myself and let the FBO know
that some non-Part 135 service had been performed on the airplane.
Heck, for that matter, I'd let the FBO know what I'd done regardless and
make them pay for the bulb.
Pete
Old December 29th 03, 07:18 PM
G.R. Patterson III
George Patterson
Great discoveries are not announced with "Eureka!". What's usually said is
"Hummmmm... That's interesting...."
Old December 29th 03, 07:20 PM
Blanche
And under no circumstances touch the new bulb with your fingers! Use
gloves or something (shirt tail?) Oil & sweat from your fingers is
not good for the bulb. In fact, if you have the box the bulbs come
in, that warning is printed (or should be) on the box.
Old December 29th 03, 07:24 PM
Ron Natalie
"Blanche" wrote in message ...
It's not going to be a problem for most position like bulbs. They have
regular glass envelopes and they don't burn hot enough to make a
difference. Quartz-halogen bulbs are a different story. The quartz
envelope on these will soften from the oils in your hands. Note that
this applies only to instances where you touch the envelope directly.
Your Q4559 bulb actually has a glass enclosure around the whole
thing (so that it will fit into the same form factor as the traditional
4559). You couldn't touch the envelope if you wanted.
Skycraft Landing Light Question Jay Honeck Owning 15 February 3rd 05 07:49 PM
The light bulb Greasy Rider Military Aviation 6 March 2nd 04 01:07 PM
USAF = US Amphetamine Fools RT Military Aviation 104 September 25th 03 04:17 PM
Effect of Light Sport on General Aviation Gilan Home Built 17 September 24th 03 07:11 AM
OT but very funny after some of the posts we have had of late. Mycroft Military Aviation 1 August 8th 03 11:09 PM
