SEE YOU RECORDER
Old September 16th 12, 02:38 AM posted to rec.aviation.soaring
glen
Default SEE YOU RECORDER
I have used the See You Recorder three time and have three invade flights on OLC
Any ideas??
Old September 16th 12, 04:37 AM posted to rec.aviation.soaring
Any ideas??
Look at the igc file - if your GPS drops out and you go more than a few seconds (Can't recall the exact number) without a valid fix, the gap in the log will cause your file will be invalid. Unfortunately, the GPS in my cellphone is crappy enough that I get this problem regularly.
Old September 16th 12, 10:13 AM posted to rec.aviation.soaring
Hi Glen.
The IGC file from the SeeYou Recorder becomes OLC valid after you have uploaded it to the SeeYou Cloud.
There's an additional beenefit in uploading to the SeeYou Cloud in that it's there waiting for you on your PC when you get home. No need to email or otherwise share the file or anything. It's there and it happens automatically (given you have left the automatic upload to the SeeYou Cloud enabled).
Once it's on your PC it's easy to submit to OLC. In fact this is for sure the most comfortable way to claim flights to OLC from iPhone/iPad right now.
See more info on this he
www.tinyurl.com/seeyou43
For the three files which you have claimed already:
1. Upload them to SeeYou Cloud from the Logbook in the SeeYou Recorder app.
2. Send them to OLC support people. They will be happy to exchange the files you have uploaded previously with the ones which will give you a blue V.
Regards,
Andrej Kolar
glider pilots use
http://www.Naviter.com
Any ideas??
FLYWITH CE recorder Brad[_2_] Soaring 3 September 12th 12 04:59 AM
New flight recorder - flyWithCE Flight Recorder uros Soaring 12 May 5th 09 09:31 PM
SN-10b EW flight recorder/PDA combination Jim Archer Soaring 5 November 18th 08 01:30 PM
EW Recorder Douglas Logan Soaring 4 August 13th 08 10:27 PM
In flight recorder Lou Piloting 23 March 24th 07 01:45 AM
