GPS-NAV model 10, 20, 25 hardware version numbers...
Old September 20th 12, 11:34 PM posted to rec.aviation.soaring
Marc
Default GPS-NAV model 10, 20, 25 hardware version numbers...
Just out of curiosity, if you have a GPS-NAV, please take a look at
one of your IGC files and check the HFRHWHARDWAREVERSION field
(only). I'm aware of units that put 38, 39, and 2.39 in this field.
If you find another number, please email the IGC (and CAI file if you
have it) file to marc.ramsey at gmail dot com...
Marc
Old September 21st 12, 05:03 AM posted to rec.aviation.soaring
I now have a report of HFRHWHARDWAREVERSION 2.38 (thanks, Ron), along with the aforementioned 2.39, 38, and 39. If you want to be certain that your GPS-NAV will continue to be an IGC approved flight recorder after the end of this month, check to make sure that HFRHWHARDWAREVERSION is reporting one of the above four numbers. If not, mail an IGC file (and the associated CAI file if you have it) to marc.ramsey at gmail dot com, as soon as possible....
Thanks again,
Marc
Old September 21st 12, 05:03 PM posted to rec.aviation.soaring
Morgan[_2_]
I appear to have Revision: F
Files sent.
Morgan
Thanks again,
Marc
EFB Hardware [email protected] Products 0 July 27th 06 10:26 PM
Another hardware question Smitty Two Home Built 4 April 21st 06 07:09 PM
AN hardware CAD files Leon McAtee Home Built 12 September 11th 04 02:33 AM
Hardware Lou Parker Home Built 10 January 31st 04 12:21 PM
Need help with hardware Paul Mennen Home Built 8 August 29th 03 03:54 AM
