Connecting two PDAs to Cambridge 302 out (Tx)
Old September 30th 12, 10:41 PM posted to rec.aviation.soaring
Andrzej Kobus
Default Connecting two PDAs to Cambridge 302 out (Tx)
I hope someone here will be able to help.
Can one safely connect two devices that would read (Rx) from Cambridge
302 (Tx)?
I have a signal right now going to ClearNav only but I would like to
split the Cambridge out signal (Tx) so I can also receive the data in
a backup PDA. The second device would only receive the data from
Cambridge not send anything.
I found some references that suggest this is commonly done with RS232
interfaces, but I am a bit suspicious since connecting 2 devices would
reduce resistance of the load. The manual says two PDAs are not
supported but it is difficult to say if this is dictated by circuit
issues or by protocol being messed up by two PDAs trying to
communicate bi-bidirectionally at the same time. Again, I only want to
receive.
Any knowledgeable reply would be appreciated.
It is also interesting to see PowerFlarm specifying that only one
external device could be connected to the DB9 serial port. I would
like to understand that as well. What is the reason for this, hardware
or software?
Old September 30th 12, 11:03 PM posted to rec.aviation.soaring
Peter Purdie[_3_]
As many devices as you like can receive 302 serial data out (at least three
anyway in my experience).
Obvously you know Andrezej, only one can transmit to the 302 and switching
is needed if you want bi-directional communication (for example, task
exchange).
The 302 serial DB-9 connector also has separate power out on pins 6 and 9
to power 2 PDAs.
302 (Tx)?
receive.
or software?
Old October 1st 12, 02:14 AM posted to rec.aviation.soaring
Andrzej Kobus
Thank you for the replies!
Spring Cleaning, PDAs Evan Ludeman[_4_] Soaring 1 June 11th 12 05:25 PM
Wanted Power/data connectors for Compaq Aero 1500 PDAs Paul Remde Soaring 3 April 16th 10 01:23 AM
Polarized Sun Glasses and PDAs Michael Reid Soaring 12 April 11th 10 02:36 PM
Seeking 2 Compaq Aero 1550 PDAs Paul Remde Soaring 0 November 13th 09 09:26 PM
Cambridge 302/Cambridge 3UTIQ255 utility/ WinPilot/iPAQ 4155 Nathan Whelchel Soaring 4 July 5th 04 11:22 PM
