Instrument Exams
Old February 1st 04, 12:56 AM
Jeb
Default Instrument Exams
Studying both for the FAA/IR and a UK IMC rating. The UK IMC give a
good clue to what it is. It allows flying in IMC but with limited IFR
privileges. Essentially it is a get home safe rating. UK weather is so
unpredicable that it is feasable to get caught out easily even with
the most thorough of planning.
Enough of that. Been doing test papers for the respective knowledge
tests. The FAA questions are quite straight forward and I am doing
good. Getting 75% right but will go for the test when I consistantly
get 85+%.
The IMC is a whole other ballgame where the theory can be a little bit
too much. The passmark is 72%.
Here is a fantastic question. No prizes for getting the right answer
(with explaination) but anyone fancy a go?
Given the following:
Ground speed 90kts
aircraft altitute 6000ft
VOR transmitter at mean sea level
Tan 40° = 0.839
assume 6000ft = 1nm
Theoretically, for approximately how many seconds would you expect the
morse identifier to be inaudible within the cone of silence if the
aircraft is tracking directly TO the VOR followed by its reciprical
directly away FROM the VOR?
A - 7 seconds
B - 20 seconds
C - 67 seconds
D - 100 seconds
Old February 1st 04, 05:54 AM
John Harlow
Ground speed 90kts
Tan 40° = 0.839
assume 6000ft = 1nm
A - 7 seconds
B - 20 seconds
C - 67 seconds
D - 100 seconds
None of the above. The "cone of slience" causes morse and any other
identifiers to become inaudible anytime the user is wearing one, as
demonstrated on several "Get Smart" episodes.
Old February 1st 04, 06:00 AM
Randy at Home
"John Harlow" wrote in message
| Ground speed 90kts
| Tan 40° = 0.839
| assume 6000ft = 1nm
| A - 7 seconds
| B - 20 seconds
| C - 67 seconds
| D - 100 seconds
Would you believe, A...?
Uh,.. how about, B...?
Missed it by ---||--- that much.
Old February 1st 04, 06:52 PM
John Bishop
Interested to hear you are doing the IMC and FAA IR. After getting my FAA
licence revalidated recently at Luton, I decided to carry on with some
training. I am now three hours into my night rating and then will finish the
IMC I started ten years ago and move on to the FAA IR. My instructor says
that I could even go for a FAA commercial licence, as I have enough hours,
but I'll leave that for now, sounds like hard work. Circuit bashing at Luton
is hard enough already, imagine Easyjet and Ryanair being told they are
number 2 to the cherokee on base!
The interesting thing I found out is that if you get the IMC and then the
FAA IR, if you fly in a "G" plane, you can use the IR rating once you leave
the UK FIR. If it's a "N" reg, then obviously no problem the whole time.
Regards
John
"Jeb" wrote in message
om...
get 85+%.
Ground speed 90kts
Tan 40° = 0.839
assume 6000ft = 1nm
A - 7 seconds
B - 20 seconds
C - 67 seconds
D - 100 seconds
Old February 1st 04, 07:41 PM
Jeb
"Randy at Home" wrote in message . cable.rogers.com...
| Ground speed 90kts
| Tan 40° = 0.839
| assume 6000ft = 1nm
| A - 7 seconds
| B - 20 seconds
| C - 67 seconds
| D - 100 seconds
The cigar goes to Bill for answer A and the explaination too. The
answer book says the following:
VOR signal propagation is omni directional in the horizontal plane but
confined to an angle of 40 degrees to the vertical which creates an
area in which there is no signal propagation. This area is known as
the Cone of Confusion or Cone of Silence.
However, the AM morse ident signal is propagated omni directionally in
both the horizontal and vertical plane and therefore audible within
the cone of silence.
There are 4 morse idents every 30 seconds. Three consecutive VOR
idents are transmitted at 7,5 second intervals followed 7,5 seconds
later by a DME morse ident if a DME is co-located with the VOR.
The nearest correct answer is A.
I have not come across a question like this in the IR knowledge test,
is it something an examiner would ask as part of the oral?
In the UK you get this in the test but examiners are not likely to ask
sucha question in the oral.
Old February 1st 04, 11:38 PM
Jeb
"John Bishop" wrote in message ...
Regards
John
Got the night qualification at Christmas when in the USA. I used to
have the IMC which I git straight after the PPL but decided that IMC
and my level of experience were not to be mixed.
Now a bit older and wiser Ihope, I can make better use of both
especially when going to the US. Having the night qualification
releases me to fly at night there. Getting the IR will complete the
set.
The advantage of having the IMC rating is that I can shoot the various
instrument procedures with that to satisfy the IR currency even if I
dont exercise the privileges of the FAA/IR. after all the book only
requires that instrument approaches are carried out, and they will be
in my logbook. With the number of approaches available at airports not
in controlled airspace it becomes even easier.
I reckon I could do 6 different types of approaches from within an
hour of where I fly from. The RAF can help out as well. With our
weather, then it makes sense to practice them anyway.
When I did my IMC, the let down I had to do on the flight test was a
VDF/DME in real IMC at Swansea (always was IMC in Swansea as well as
very windy). That was fun and required a lot of work as I remember
having to continually transmit for the QDM and QDR.
Old February 2nd 04, 07:18 AM
John Bishop
Your flight test was similar to my first night lesson. I was told it was to
be "an appreciation of instruments" refresher. My instructor is an IR rated
737 pilot, so we took off in iffy weather, entered cloud at 600ft and didn't
see anything but the wings until we popped out of cloud at 700ft on
approach! My first instrument flight for ten years and I did quite well.
John
om...
FAA
says
hours,
Luton
leave
Regards
John
set.
Old February 2nd 04, 08:01 AM
Thomas Borchert
John,
Actually, it's not. The big issue is the written - the flying part is
just more precise flying and the Chandelle bit.
Thomas Borchert (EDDH)
Instrument Checkride passed (Long) Paul Folbrecht Instrument Flight Rules 10 February 11th 05 02:41 AM
Instrument Rating Checkride PASSED (Very Long) Alan Pendley Instrument Flight Rules 24 December 16th 04 02:16 PM
Tips on Getting Your Instrument Rating Sooner and at Lower Cost Fred Instrument Flight Rules 21 October 19th 04 07:31 AM
Logging approaches Ron Garrison Instrument Flight Rules 109 March 2nd 04 05:54 PM
PC flight simulators Bjørnar Bolsøy Military Aviation 178 December 14th 03 12:14 PM
