Anderson power poles do show an alternative.. soldering... for the
connection pins if you don't have the special (expensive) crimping tool. I have used both soldering and crimping with great results. Just about everything I own has a power pole connection, glider battery, motorcycles, electric scooter...battery chargers, GPS, r/c stuff, etc....so everything is "universal" Cookie |
On 11/27/2012 6:55 PM, Bob Cook wrote:
Anderson power poles do show an alternative.. soldering... for the connection pins if you don't have the special (expensive) crimping tool. I use the Andy-Crimp tool. Less than 25% of the price of the "official" Anderson crimper. Works great. See: http://www.hamcq.com/powerpoles/powe.../prod_485.html http://www.qsradio.com/Powerpoles.htm Tony "6N" W1DYS |
I'm another PowerPole fan.
Here's a pic of how I protect my batteries: https://picasaweb.google.com/lh/phot...t=d irectlink I make a "hat" with 3 pieces of acrylic (acrylic cement melts them together quickly and easily), then use some double-sided tape (VHB) to attach them to the battery with a ~1 inch air gap. In the air gap I mount an insulated fuse to protect the battery/wiring (in addition to fuses or CBs for each instrument). I drill a couple of small holes in the acrylic and zip-tie the fuse in place so the wires aren't under tension. Then I drill another small hole in the acrylic and use a screw, lock- washer, and nut to hold the PowerPole in place with no tension on the battery wires (the PowerPole housing insulates everything from the screw). Being screwed into the acrylic means I can push and pull on the connection if I need to, and it won't put strain on the wires. Lastly, I make sure this connector is recessed a bit so I can make the connection - but anything dropping onto the connection will be shielded by the acrylic. Enjoy, --Noel |
| Thread Tools | |
| Display Modes | |
| Battery plugs, etc. | Don[_4_] | Soaring | 33 | December 1st 12 06:20 AM |
| Spark plugs | Don Pyeatt | Aviation Photos | 4 | April 9th 07 05:25 AM |
| RFQ Igniter plugs | Juan*Jimenez | Aviation Marketplace | 0 | April 24th 04 12:13 AM |
| GPS ext power plugs | Dave Martindale | Piloting | 0 | September 16th 03 10:26 PM |
| GPS ext power plugs | Dave Martindale | Products | 0 | September 16th 03 10:26 PM |
