Tailwheel For GROB Twin Astir
Old December 2nd 12, 09:28 PM posted to rec.aviation.soaring
Mike J.
Default Tailwheel For GROB Twin Astir
Over the years we've managed to "deflate" the tailwheel on our club's Twin Astir due to rough landings, rocks, cactus, whatever. It has always been a pain to remove and replace the tire/tube and often the 90-degree valve stem on the tube we buy is a bit long and hits the fiberglass tailwheel fairing..
Anyone out there have a solution/idea/suggestion on a replacemnet non-pneumatic tire that would do the job?
Mike J.
Old December 2nd 12, 09:45 PM posted to rec.aviation.soaring
Eric Munk
Twin
a
stem=
fairing=
non-pneum=
Mike J.
A 45-degree valve stem fixed with a locking wire to the rim (drill a small
hole) will halve the amount of flats. Stops the valve stem from being
ripped off the tube.
Old December 3rd 12, 05:49 PM posted to rec.aviation.soaring
aerodyne
Ditto. I will add that Tim at W&W has the tube you need, page 33 on
his website. Desser does not carry it IIRC.
aerodyne
Grob 102 Astir CS fredblair Soaring 1 February 18th 12 12:06 PM
Looking for Grob Twin Astir Gear Retract Mechanism AJM Soaring 0 August 18th 09 06:03 AM
Grob 102 Astir Std III [email protected] Soaring 0 May 30th 07 10:27 PM
Grob Twin Astir Tailshaking Peter Soaring 11 January 15th 07 12:54 AM
Grob Twin Astir 1 Manual / Flughandbuch Sebastian Schroeter Soaring 2 June 14th 04 12:41 PM
