Registration Numbers
Old February 28th 13, 10:01 PM posted to rec.aviation.soaring
Peter von Tresckow
Default Registration Numbers
So I am scraping paint on my Ka-6, and I am getting to the point of
designing a new paint scheme.
First off am I correct in my interpretation that I can put 2" numbers on my
Ka-6 being older than 1981?
Second wasn't there an exemption from those regs anyway? I searches the SSA
site for this, but I couldn't find it.
Thanks
Peter
Old March 1st 13, 12:17 AM posted to rec.aviation.soaring
Tony[_5_]
Yes you can use 2" numbers I'm pretty sure. The exemption which is now permanent in the regs is for external data plate.
Old March 1st 13, 12:27 AM posted to rec.aviation.soaring
Thanks
Peter
Look at 14CFR Part 45 sections 21-33 for regs
It is very clear that 3" is OK for gliders Part 45.29(b)(ii)
Part 45.22(b) seems to limit the antique use of 2" to experimental
I used 3" on my last project and did not worry about it.
Old March 1st 13, 12:48 AM posted to rec.aviation.soaring
Steve Leonard[_2_]
On Thursday, February 28, 2013 5:27:46 PM UTC-6, wrote:
Look at 14CFR Part 45 sections 21-33 for regs It is very clear that 3" is OK for gliders Part 45.29(b)(ii) Part 45.22(b) seems to limit the antique use of 2" to experimental I used 3" on my last project and did not worry about it.
45.22(b) says if it is small and over 30 years old, it can use 2 inch. The "or" in there is so that you could make a new plane that looks like an old plane and put 2 inch numbers on it. Not limited to just antique experimental.
Yes, Pete. You can use 2 inch high numbers. Google 14CFR, then look at Part 45. It will tell you all you ever wanted to know and then some. The only thing magical about 1981 is that for a short time, they permitted new planes to have 2 inch high numbers on them. And they can stay that way until the plane is re-painted.
Personally, I like the big numbers on the side of my Ka-6. Helps it look more sleek!
Steve
Experimental FAA registration [email protected] Soaring 16 June 14th 08 05:13 AM
tail numbers and countries of registration William Hung[_2_] Piloting 40 March 5th 08 05:59 PM
tail numbers and countries of registration William Hung[_2_] Owning 39 March 5th 08 05:59 PM
De-registration [email protected] Soaring 11 August 24th 07 07:09 AM
OLC Registration [email protected] Soaring 7 April 17th 07 05:10 PM
