LX v7 vario won't play audio sound
Old March 30th 13, 01:18 PM posted to rec.aviation.soaring
Default LX v7 vario won't play audio sound
The audio function is stopped working mid flight. I went to the volume screen and adjusted the volume up all the way, still no sound. I then powered it off, back on, hoping to reset it with no luck.
After I landed, I unplugged each wire going to the V7 and re plugged it back in. All connections look good. The speaker works fine still as its shared with the radio.
Any troubleshooting advice is welcomed here.
SA
Old March 30th 13, 01:33 PM posted to rec.aviation.soaring
Richard[_9_]
On Saturday, March 30, 2013 6:18:42 AM UTC-7, wrote:
The audio function is stopped working mid flight. I went to the volume screen and adjusted the volume up all the way, still no sound. I then powered it off, back on, hoping to reset it with no luck. After I landed, I unplugged each wire going to the V7 and re plugged it back in. All connections look good. The speaker works fine still as its shared with the radio. Any troubleshooting advice is welcomed here. Thanks, SA
Scott,
How did you connect the speakers? Series or parallel. It is important depending on the connection you may have overdriven the amp. Please see this link for an explanation.
http://www.bcae1.com/spkrmlti.htm
Richard
www.craggyaero.com
Old March 30th 13, 06:44 PM posted to rec.aviation.soaring
JS
Putting the outputs of two amplifiers together is not a good idea.
Saw it done with two 2000W professional amplifiers last week, they worked again when the short was removed.
CAV 11 Audio Vario/no Audio ideas? (Cambridge) Gregg Leslie[_2_] Soaring 3 June 4th 11 12:08 AM
Schematics for Cambridge CVS50 vario and audio unit? Or anyoneselling a similar working audio variometer? Bret Soaring 0 August 30th 10 04:24 AM
MP3 of e-Vario sound Sebastiaan Soaring 3 May 11th 05 05:49 AM
L-13 + TE + Audio Vario Ray Lovinggood Soaring 4 January 12th 05 03:21 AM
Vario Sound for my mobile phone jorgie Soaring 1 October 18th 04 04:21 PM
