LS-6b Spoiler Issues
Old April 1st 13, 12:23 AM posted to rec.aviation.soaring
Stu
Default LS-6b Spoiler Issues
A friend of mine has a LS-6b and on several recent occasions the spoilers have opened when he changes the flap settings during normal flight. The linkage for the spoilers goes through the push tube that operates the flaps and sometimes that has deployed the spoilers during normal cruising flight. Has anyone else had that problem and what has been the solution to the problem. During the last several annuals we have tried to clean the tube and pushrods, but it has not helped much.
Old April 1st 13, 03:17 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
One of the spoilers may not be going into complete over-center locking position. I'd check each wing separately for complete and proper lock that pulls the spoiler down approximately 2mm after the cap seats flush in the wing. This is easily checked by lifting the spoiler cap and sliding several dimes under the cap, then close and lock the spoiler. Locked spoiler cap should be flush.........don't forget to retrieve your dimes. It should take 5 to 10 pounds of force to lock each properly adjusted spoiler.
Hope this helps,
JJ
Old April 1st 13, 06:54 PM posted to rec.aviation.soaring
Stu
Thanks JJ. That is what I suspected. We will see if that fixes the issues..
Spoiler Signal [email protected] Soaring 14 August 2nd 11 09:22 PM
using less spoiler just before the flare??? Gary Emerson Soaring 16 October 29th 07 02:08 PM
Landing with one spoiler [email protected] Soaring 82 October 7th 05 01:58 AM
Nimbus 3 25.5 tip spoiler cable replacement tango4 Soaring 0 May 3rd 04 10:05 PM
Spoiler placement and design. B2431 Home Built 9 November 11th 03 05:02 PM
