Possible Damage to Cambridge 302
Old April 26th 13, 01:37 AM posted to rec.aviation.soaring
Dan Marotta
Default Possible Damage to Cambridge 302
Had my canopy off today to do some work behind the panel. I accidentally
leaned against the panel and it slammed down. I powered up and everything
works except for the CAI302. The display turns on and, IIRC, the needle
swung, but it never got beyond the second screen, the one which displays a
number at the top and the firmware version at the bottom.
The wind got pretty strong today at Moriarty so I put it back in the
trailer. My plan for tomorrow is to disconnect everything and reconnect
thinking that a connector or wire might have come loose. There's no
indication of damage by looking at the screen. Any suggestions?
Old April 26th 13, 02:20 AM posted to rec.aviation.soaring
Papa3[_2_]
Call Tim Mara - he could probably help.
Old April 26th 13, 04:26 AM posted to rec.aviation.soaring
Evan Ludeman[_4_]
Unplug the OAT sensor and try again.
-T8
Old April 26th 13, 04:12 PM posted to rec.aviation.soaring
Dan Marotta
Thanks, Guys, you've given me hope. It was just a bit over a year ago that,
in flight, the needle fell off the bloody thing and I had to send it off.
It didn't fall off this time.
"Paul Remde" wrote in message
Hi,
After unplugging the temperature probe, plug it back in and make sure it
is fully seated. Then power the 302 up.
Paul Remde
Cumulus Soaring, Inc.
"Evan Ludeman" wrote in message
everything
a
-T8
Old April 27th 13, 03:15 AM posted to rec.aviation.soaring
Dan Marotta
Thanks Guys! Simply removing and reseating the OAT sensor plug did the
trick.
Oh, and yeah... My remotely mounted meat thermometer is also great! At
16,800' MSL, the temperature was 8 deg F. Now I'm sure I know the reason my
feet were cold!
According to my XCSoar program, one of the thermals I entered registered
17.5 kts! Of course, my average was only in the 11+ range. The season is
really getting going here in New Mexico.
"Dan Marotta" wrote in message
that, in flight, the needle fell off the bloody thing and I had to send it
off. It didn't fall off this time.
Hi,
Paul Remde
accidentally
everything
a
-T8
Old April 27th 13, 11:48 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
accidentally leaned against the panel and it slammed down. I powered up
and everything works except for the CAI302. The display turns on and,
IIRC, the needle swung, but it never got beyond the second screen, the
one which displays a number at the top and the firmware version at the
bottom.
I sort of remember the temperature probe can cause funny stuff if it's
not plugged in correctly or is damaged. Make sure it's secure; if that
doesn't work, try unplugging it.
The technician at Cambridge has been helpful in the past when I had a
problem.
email me)
Old April 28th 13, 05:01 PM posted to rec.aviation.soaring
Dan Marotta
Thanks, Eric
As I reported the other day, it was, in fact, the probe. It must have
gotten jarred loose when the panel slammed down. Simply unplugging and
plugging it back in fixed the problem. I'll file that one away for future
reference.
bottom.
I sort of remember the temperature probe can cause funny stuff if it's not
plugged in correctly or is damaged. Make sure it's secure; if that doesn't
problem.
Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email
me)
Old May 8th 13, 10:01 PM posted to rec.aviation.soaring
JohnDeRosa
For those that keep odd 302 facts in a file somewhere....
Over the winter I took my instrument panel home to putter. About 3 months later I turned on the unit and found the the 302 would cycle its start up tones over and over again for minutes before getting to the "set pressure" screen. I ultimately found that it had to do with the GPS. I had cleared the memory on the 302 which, I assume, also cleared the last know GPS location. So the 302 had to start from scratch to find satellites and get a fix.... plus I was indoors at the time. Once outside and a fix was made, startup now happens normally.
Cambridge 302 & PDA -- Value of adding Cambridge 303? V1 Soaring 5 July 31st 07 04:51 AM
Needs damage control gaylon9 Rotorcraft 0 November 15th 04 02:01 AM
NAS Pensacola Damage Brad Naval Aviation 14 September 25th 04 01:12 AM
Cambridge 302/Cambridge 3UTIQ255 utility/ WinPilot/iPAQ 4155 Nathan Whelchel Soaring 4 July 6th 04 12:22 AM
X-15 damage Paul F Austin Military Aviation 7 May 23rd 04 10:11 PM
