New PDA with e-ink display, internal barometer, gps etc.
Old May 11th 13, 02:57 PM posted to rec.aviation.soaring
Default New PDA with e-ink display, internal barometer, gps etc.
A new PDA is coming to market. This one is quite different from what we've seen in the past. I would buy this in a heartbeat if I knew it would run X/C Soar. I'm interested in others opinions about the chances of this working in the cockpit.
Brian Bange
Here's the specs:
Android 4.1 • Flexible 6" E-ink screen (1024x768) • Sunlight viewable with lunar lantern mode • Glove friendly IR touchscreen • Waterproof shell • Kickstand • Solar charging • i.MX 6 DualLite 1GHz Cortex A9 • 1GB ram • 16GB memory + microSD • Wifi b/g/n • BT 4.0 • ANT+ • NFC • FRS/GMRS/MURS • GPS + GLONASS • Accelerometer • Gyroscope • Magnetometer • Temperature • Barometer • Humidity • Anemometer • AM/FM/SW/LW • IR blaster • 20+ hour battery • 20" usb lanyard • 303 grams (10.8 oz) • 183mm x 121mm x 15mm (7.2" x 4.75" x 0.6")
Here's the URL:
http://www.meetearl.com/
http://www.gizmag.com/earl-tablet-ba...urvival/27446/
Old May 11th 13, 04:28 PM posted to rec.aviation.soaring
Neil McLaughlin[_2_]
Well it runs on Android so it's extremely likely to work I'd have thought.
Spec looks good, price is good, curious as to the size it's verging on a
tablet
size though!
Neil
we've
X/=
working=
in the cockpit.
Brian Bange
Here's the specs:
Android 4.1 =95 Flexible 6" E-ink screen (1024x768) =95 Sunlight
viewable=
with lunar lantern mode =95 Glove friendly IR touchscreen =95 Waterproof
s=
hell =95 Kickstand =95 Solar charging =95 i.MX 6 DualLite 1GHz Cortex A9
=95 1GB ram =95 16GB memory + microSD =95 Wifi b/g/n =95 BT 4.0
=95 ANT+ =
=95 NFC =95 FRS/GMRS/MURS =95 GPS + GLONASS =95 Accelerometer
=95
Gyroscope=
=95 Magnetometer =95 Temperature =95 Barometer =95 Humidity =95
Anemometer=
=95 AM/FM/SW/LW =95 IR blaster =95 20+ hour battery =95 20" usb
lanyard =
=95 303 grams (10.8 oz) =95 183mm x 121mm x 15mm (7.2" x 4.75" x
0.6")
Here's the URL:
Old May 11th 13, 07:58 PM posted to rec.aviation.soaring
son_of_flubber
One thing that you'll want to investigate further is the e-ink display.
The folks at http://tophatsoaring.wikispaces.com/Top+Hat have a derivative of XCSoar that run on a B&N Nook which also uses an e-ink display. Not all e-ink displays are the same, but they have the potential for ghosting (an afterimage shows for anything moving across the display). I understand that the Top Hat folks have overcome this problem to some extent by rooting the Nook and installing a graphics driver that "dithers". Ghosting may not be a problem on the new tablet, or there might be something that precludes (or delays implementation of) the dithering 'solution'. You can investigate the ghosting issue on the new tablet by asking whether it supports "gaming" (ghosting is a problem for gaming).
I would post something at tophatsoaring to spark a discussion of this tablet if those same folks don't soon join in here soon.
You might also keep an eye on Tophat. They hook an external GPS source to the Nook through a cable. The advantage being the Nook is a more manageable size and you can buy a new one for $50 on Ebay. The Nook displays "greyscale" aka no color.
Old May 12th 13, 06:45 AM posted to rec.aviation.soaring
Darryl Ramm
Brian Bange
Here's the specs:
Here's the URL:
A new PDA *might* be coming to market. They are currently 28% funded of their $250,000 goal on Kickstarter with 30 days to go.
Darryl
Old May 12th 13, 09:37 AM posted to rec.aviation.soaring
Matt Herron Jr.
e ink has a very slow refresh rate, so probably not suitable for moving maps, flarm alerts, thermal finders, rapidly changing numbers, etc.
Old May 12th 13, 09:45 AM posted to rec.aviation.soaring
Darryl Ramm
The devil will depend on the details. Look at those Tophat nook videos, very impressive for an eink display.
Darryl
Old May 12th 13, 10:01 AM posted to rec.aviation.soaring
Kimmo Hytoenen
moving
If it works like this, I can fly with it:
http://www.youtube.com/watch?v=U7ZwZppiIr8
The size is a problem for me, max. 5 inch would fit into our club
ships.
Another important thing is charging and connecting with variometer
and FLARM. We use IOIO cards for charging and data
communication. I hope the IOIO-OTG works with nook and other
similar devices.
Streak is still good enough.
Google Android to add Barometer Support Mike the Strike Soaring 0 January 17th 11 09:41 PM
WTB: Barometer/Altimeter for VXA210 SU-1 RF stuff Aviation Marketplace 0 September 22nd 07 02:29 PM
Barometer Setting in Europe question... Piloting 19 April 3rd 05 10:43 PM
Barometer Setting in Europe question... Altitudes in 100' multiples? Piloting 1 April 2nd 05 04:35 PM
Hello, kingbee, Do not release, its the internal rls! Frank Laczko Home Built 0 February 13th 04 07:59 PM
