700 agl / 1 mile finish
Old May 24th 13, 04:04 PM posted to rec.aviation.soaring
Evan Ludeman[_4_]
Default 700 agl / 1 mile finish
Man, what a pain in the ass at Mifflin.
Returning on the back side of Jacks with weak ridge and no thermals, you leave the ridge at 1900-2000 because you *cannot* get higher and fly through a ton of sink (netto 4 - 6 kts down is common). The closest point of the ridge to the edge of the finish cylinder is 1.6 SM and the 700' agl finish is 1520. You'd probably prefer to cut the corner if energy allows, but that makes the distance more like 3 miles. Twice I was hanging on my flaps at 42 kts at what I guessed to be the edge of the cylinder (when the gps says 1.0 mile, you've generally finished several seconds earlier). Eyes on the panel, about 1530 feet, right in the GA traffic pattern (amazing how many GA pilots don't read Notams and show up at closed airports!). This is safer than an eyes out finish at lower altitude? I don't think so. I fly a '20.. What's a Libelle pilot supposed to do in that situation? We never found out because none of the low performance guys had to try to make this work.
I don't have a problem with penalizing actual unsafe flying. However, we're now erring on the side of penalizing (severely) *potentially* unsafe flying. Two guys I know of (there may have been others) drew no speed points after hitting the cylinder below 1320 agl. In both cases the airport arrivals were reasonable energy and safe.
Evan Ludeman / T8
Old May 24th 13, 04:21 PM posted to rec.aviation.soaring
Returning on the back side of Jacks with weak ridge and no thermals, you leave the ridge at 1900-2000 because you *cannot* get higher and fly through a ton of sink (netto 4 - 6 kts down is common). The closest point of the ridge to the edge of the finish cylinder is 1.6 SM and the 700' agl finish is 1520. You'd probably prefer to cut the corner if energy allows, but that makes the distance more like 3 miles. Twice I was hanging on my flaps at 42 kts at what I guessed to be the edge of the cylinder (when the gps says 1.0 mile, you've generally finished several seconds earlier). Eyes on the panel, about 1530 feet, right in the GA traffic pattern (amazing how many GA pilots don't read Notams and show up at closed airports!). This is safer than an eyes out finish at lower altitude? I don't think so. I fly a '20. What's a Libelle pilot supposed to do in that situation? We never found out because none of the low performance guys had to try to make this work.
Evan Ludeman / T8
The finish altitude is set by the CD to whatever he or she feels is appropriate for the airport, surrounding terrain, traffic issues, weather, etc. There is no rule regarding its value.
The guidance -- guidance, not rule -- to 700' AGL (Which means 500' AGL for speed points) has in mind thermal flight, reasonable surrounding terrain, and a normal airport. The point is to reduce the otherwise strong incentive to try marginal glides that either pop over the fence at the last moment, or result in a hasty off field landing 1 mile out and "planned" from about 100 feet AGL.
The guidance suggests even higher altitudes for rough surrounding terrain, airports with little room for multiple landings, or airports with power traffic.
The situation at Mifflin on a backside ridge day certainly seems plausibly appropriate for a lower altitude. There is no temptation to squeak low final glides -- you're all coming off the back of the ridge at the same point and altitude, and your only choice from then on is to push or float. 500' AGL has worked fine in the past in this situation.
But... I can naturally see a harried CD not thinking about this ahead of time. It's a subtle point. Did you or any of the pilots notice this might be a problem ahead of time and suggest a lower finish altitude to the CD for that day only? The rules give a lot of flexibility for a reason, but you can't expect rules to foresee every possibility, especially if wise CDs, task advisers, and pilots in place aren't seeing that possibility! Really, I don't think you get to complain unless pilots and task advisers saw the problem, explained this issue to the CD ahead of time, and the CD refused the request.
Otherwise, let's all file in the lesson learned category. 500' finish for backside ridge days. Check.
John Cochrane
Old May 24th 13, 04:32 PM posted to rec.aviation.soaring
John Carlyle
Evan Ludeman / T8
I absolutely agree. I was one of the two penalized pilots, so my comments could be taken as sour grapes.
When you consider, however, that there was no shortening of the downwind, base or final legs, that I was using spoilers during all legs to lose altitude, and my speed was never below 55 kts until the flare, I think you'll agree that this new rule is too severe.
If this comes up for a vote this year, I will be supporting a minimum 500 foot arrival at 1 mile, with graduated penalties down to the surface.
-John, Q3
Old May 24th 13, 04:43 PM posted to rec.aviation.soaring
Evan Ludeman[_4_]
Evan Ludeman / T8
John Cochrane
We understand all those points. The thing is, people will tend to go with guidance by default.
It isn't just the "classic" back side sailplane time trial days at Mifflin, either. The back side ridge came into play one other day when no one would have forecast such a thing. It was weak, the angle stunk, the thermals were gone. Given the terrain around Mifflin, there really isn't any good reason to set the finish height above 1320 at any time.
As far as tasking goes... talk about harried! Nothing like getting the Mifflin special "no repeat MAT" for 4 hours, about 20 minutes before launch! If anyone was thinking ahead to the finish gate height, it certainly wasn't me. I didn't even realize we were using 700 agl (we'd discussed on practice day and what I'd heard was that we'd use 500 / 1 mile cylinder or a 50' gate if tasking allowed) until I approached the first finish and wondered why 600 over the airport on my 303 display was showing 100 low on ClearNav.
T8
Old May 24th 13, 04:46 PM posted to rec.aviation.soaring
Evan Ludeman[_4_]
Evan Ludeman / T8
-John, Q3
That makes three.
T8
John Carlyle
...[Big clip...]
John Cochrane
With all due respect, putting this on the pilots is crap. We'd flown 5 hard, long days at this point, were all tired, and had no idea of what kind of lift we'd get from the back of Jack's. Further, some of us are relatively new to the contest scene and aren't "rule wonks", while all of us were new to the "guidance" being discussed. The "guidance" is too conservative and needs to be changed, period.
-John, Q3
Old May 24th 13, 05:34 PM posted to rec.aviation.soaring
Evan Ludeman[_4_]
Argh. That's a typo. MiffCo airport is 819 MSL, finish was 1520 MSL, no speed points at 1320 MSL.
T8
Old May 24th 13, 05:43 PM posted to rec.aviation.soaring
That makes three.
T8
While I appreciate the feedback, I would hope you'd consider how the rule works at a variety of contests and weather conditions, rather than have us design and modify a rule according to how it worked on one day at Mifflin, in rather special weather and rather special orientation of airport and ridge.
The rule is designed for thermal tasks at 99% of airports. It is written flexibly enough so that it can be adapted to the special circumstances of Mifflin on a backside ridge day. Does it really make sense to write the rule for all the 99% of circumstances thinking only about how it worked on a backside ridge day?
Last, when thinking about a rule like this one, adding up the number of times a pilot got a penalty, but feels he or she had adequate energy misses the whole point. We need to also add up the number of times pilots don't have adequate energy. 5 clicks in a row does not make Russian Roulette safer.
So, I would encourage you all to take a deep breath, and evaluate how finishes are working out in all of your contests this season, especially when you face a tough final glide over rough terrain.
And, next time there is a backside ridge day at Mifflin, encourage the CD to lower the finish altitude.
John Cochrane
Old May 24th 13, 05:44 PM posted to rec.aviation.soaring
Tom Kelley #711
Evan Ludeman / T8
10.9.2.2.1 ‡ Each task shall include a Minimum Finish Height (MFH), set by the CD at least high enough that pilots who obtain
a valid finish can return to the home airfield for a normal pattern and landing.
Here's the rule Evan. The CD has no become responsible to make sure you have enough altitude so you, Evan, can fly a "normal pattern".
Old May 24th 13, 06:11 PM posted to rec.aviation.soaring
John Godfrey (QT)[_2_]
Evan Ludeman / T8
Help. I need a realistic solution for the times and places where for some good reason the race must end somewhere other than the airport. This situation really does arise.
It seems to me that a graduated penalty all the way to the ground is just another way of saying "the race always ends at the airport."
For example, at Minden you must not have gliders arriving at the airport below pattern altitude as part of a normal task completion.
So ideas please.
John Godfrey (QT)
RC Chair
750 mile flights in Tennessee Chilhowee Soaring 2 April 10th 07 06:28 AM
1,000 mile ridge flight 4-05-07 [email protected] Soaring 5 April 8th 07 02:09 PM
24,000 mile scenic? Roger Long Piloting 19 February 9th 05 09:28 PM
Three Mile Island Photos Badwater Bill Home Built 4 February 15th 04 06:25 PM
ADV: MIle High supplier David Campbell Soaring 0 August 7th 03 03:16 AM
