I just had my first flight with my newly updated PowerFlarm. I was able to download the ICG file to the microSD card and it all worked great.
BUT, (there's always a but), I also had another recorder (XCSoar, thank you VERY much) and compared the files with SeeYou. It appears the PF is recording at a rate of about a point about every 10-12 seconds. I'd like to have files with a little more detail. Does anyone know if/how the rate can be changed? Mike |
On Friday, 31 May 2013 21:47:49 UTC-6, SoaringXCellence wrote:
I just had my first flight with my newly updated PowerFlarm. I was able to download the ICG file to the microSD card and it all worked great. BUT, (there's always a but), I also had another recorder (XCSoar, thank you VERY much) and compared the files with SeeYou. It appears the PF is recording at a rate of about a point about every 10-12 seconds. I'd like to have files with a little more detail. Does anyone know if/how the rate can be changed? Mike Mike The B records of the IGC file are the fix records A4.1.1 The format of the basic data, with extra spaces for clarity, is: B HHMMSS DDMMM MmmmN DDDMMmmm E V PPPPP GGGGG CR LF The one IGC file I reviewed from a PF had a 8 second interval on the ground and 4 seconds once in the air. Open the IGC with an application like NOTEPAD and look at the file I do not know how you can specify with PF the recording interval. Ron |
Hi,
Yes. Use the PowerFLARM Portable Configuration File creating tool he http://www.butterfly-avionics.com/in...able-config-en It has a parameter for the logging interval. Best Regards, Paul Remde Cumulus Soaring, Inc. ______________________________________________ "SoaringXCellence" wrote in message ... I just had my first flight with my newly updated PowerFlarm. I was able to download the ICG file to the microSD card and it all worked great. BUT, (there's always a but), I also had another recorder (XCSoar, thank you VERY much) and compared the files with SeeYou. It appears the PF is recording at a rate of about a point about every 10-12 seconds. I'd like to have files with a little more detail. Does anyone know if/how the rate can be changed? Mike |
On May 31, 11:56*pm, "Paul Remde" wrote:
Hi, Yes. *Use the PowerFLARM Portable Configuration File creating tool hehttp://www.butterfly-avionics.com/in.../powerflarm-en... It has a parameter for the logging interval. Best Regards, Paul Remde Cumulus Soaring, Inc. ______________________________________________ "SoaringXCellence" *wrote in message ... I just had my first flight with my newly updated PowerFlarm. *I was able to download the ICG file to the microSD card and it all worked great. BUT, (there's always a but), I also had another recorder (XCSoar, thank you VERY much) and compared the files with SeeYou. *It appears the PF is recording at a rate of about a point about every 10-12 seconds. *I'd like to have files with a little more detail. Does anyone know if/how the rate can be changed? Mike From the FLARM dataport specification March 2012, version 6.00E, preliminary: quote: Sub-Sentence PFLAC,,LOGINT Syntax: PFLAC,QueryType,LOGINT,Value Meaning: The value indicates the time interval in seconds between two data points of the flight recording. Consider that FLARM writes flight data to the memory about every 30 data points. When FLARM is switched off this period of the flight might not be stored. The higher the time interval between two data points, the longer is the period of the flight that is lost. Therefore do not use settings higher than 4s. FLARM should not be switched off immediately after an aircraft has landed. On the other hand the interval between two points also affects the overall recording capacity in terms of flight duration. The memory in FLARM is shared between the obstacle database and the flight recorder. The obstacle database defines the amount of memory available for flight recording. If the obstacle database is empty, FLARM can store approximately 96’000 data points of the flight. With the default 2s interval this is an equivalent of more than 50 hours. Typically, about one third of the memory is available for flight recording, resulting in more than 50 hours at 2s interval. If the flight recording memory is full, old flight data is overwritten. Values: integer values from 1 to 8 are possible, default is 2. unquote so logging interval can be no higher than 8 seconds. Your flarmconfig.txt file probably has something like this (if not, you can cut-and-paste it in): ################################################## ###################### # igc recording configuration ################################################## ###################### # recording interval $PFLAC,S,LOGINT,2 Change the integer from 2 if you want to change your interval. With this sentence, my igc file B records show an interval of 2 seconds. S is "set". Dan 2D |
On Friday, May 31, 2013 8:47:49 PM UTC-7, SoaringXCellence wrote:
I just had my first flight with my newly updated PowerFlarm. I was able to download the ICG file to the microSD card and it all worked great. BUT, (there's always a but), I also had another recorder (XCSoar, thank you VERY much) and compared the files with SeeYou. It appears the PF is recording at a rate of about a point about every 10-12 seconds. I'd like to have files with a little more detail. Does anyone know if/how the rate can be changed? Mike Thanks for the info, I've got the CFG file and I'll load it. |
As others have commented, use the 'logint' parameter. Notice that the interval is longer before takeoff and after landing, maybe you've seen this? Default logint is 4 seconds. Best --Gerhard (FLARM dev mgr) |
| Thread Tools | |
| Display Modes | |
| PowerFLARM Mode S question | kirk.stant | Soaring | 54 | October 26th 10 03:51 PM |
| Question: Standard rate turns, constant rate turns, and airspeed | Robert Barker | Piloting | 5 | April 15th 07 05:47 PM |
| camcorder recording Cessna intercom audio question | Marty from Sunny Florida | Owning | 7 | November 15th 04 05:26 PM |
| Newbie question on Rate of Climb | Wright1902Glider | Home Built | 0 | August 17th 04 04:48 PM |
| Lapse Rate Question | Waduino | Soaring | 0 | October 1st 03 08:32 PM |
