IGC-approval for the FlarmMouse Flight Recorder
Old August 2nd 13, 01:37 PM posted to rec.aviation.soaring
Ian Strachan
Default IGC-approval for the FlarmMouse Flight Recorder
I am pleased to announce IGC-approval for the FlarmMouse Flight Recorder produced by LXNAV d.o.o. of Celje, Slovenia. This uses Flarm-IGC firmware mounted in a small case by LXNAV. Its IGC-approval document can be found on the GFAC and FAI/IGC web sites given below. The IGC-approval level is for badge flights up to and including the three Diamonds.
There are now 48 types of IGC-approved Flight Recorders from 17 different manufacturers.
For the GFAC web site, see:
www.ukiws.demon.co.uk/GFAC
The table of all IGC-approved FRs with links to Approval Documents is at:
www.ukiws.demon.co.uk/GFAC/igc_approved_frs.pdf
This file contains:
(1) a table of all types of IGC-approved Flight Recorders in alphabetical order of manufacturer name, with links to their IGC-approval documents.
(2) a table of Manufacturers of IGC-approved Flight Recorders, in alphabetical order of manufacturer name.
(3) a list of all IGC-approval activity from 1996 to the present day.
(4) a history of IGC GNSS Flight Recording.
The FlarmMouse IGC-approval document is at:
http://www.ukiws.demon.co.uk/GFAC/ap...flarmmouse.pdf
This will display the document in PDF format and it can then be saved.
For the IGC web site:
http://www.fai.org/gnss-recording-de...ight-recorders
Scroll down to "IGC-Approved Flight Recorders - Approval Documents"
Then click on the box underneath the above heading which says:
"IGC-approval Documents for all IGC-approved Flight Recorders".
This will call up a list of documents, the first one being "IGC-approval tables" with links to individual Approval documents.
This is followed by IGC-approval documents in alphabetical order of manufacturer’s name. Scroll down to the Recorder type and click on its name. The IGC-approval document will then download automatically to the directory that you have set for downloads, without being displayed on screen first.
IGC-approval follows test and evaluation by the IGC GNSS Flight Recorder Approval Committee (GFAC) in accordance with Annex B to the Sporting Code for gliding and the Technical Specification for IGC-approved GNSS Flight Recorders.
The Technical Specification is available through the igc-approved-flight-recorders web site above or directly from the GFAC web site:
http://www.ukiws.demon.co.uk/GFAC/do..._spec_gnss.pdf
The Sporting Code for gliding (SC3) and its annexes A-D may be downloaded via www.fai.org/igc-documents
Ian Strachan
Chairman, IGC GNSS Flight Recorder Approval Committee
LX7007FC Flight Recorder gains IGC-approval. Ian Strachan Soaring 0 January 24th 12 03:11 PM
New type of Flight Recorder gains IGC-approval Ian Strachan Soaring 0 August 31st 11 07:21 AM
IGC-approval of the LXNAV Nano GNSS Flight recorder Ian Strachan Soaring 5 September 1st 10 03:41 PM
New IGC-approval for GNSS Flight Recorder Ian Strachan Soaring 0 February 14th 09 09:00 PM
IGC-approval issued for Aircotec GPS Flight Recorder Ian Strachan Soaring 0 May 31st 06 12:47 AM
