Weight and Balance - a micro-rant
Old August 28th 13, 10:30 AM posted to rec.aviation.soaring
Uncle Fuzzy[_2_]
Default Weight and Balance - a micro-rant
I have a sample size of TWO, so take this or leave it.
In BOTH the Speed Astir and Janus C log books, some previous owner had made pen-and-ink' changes to the distance from the main wheel to the tail wheel.. In BOTH cases, the factory figure was correct, and the ink changes incorrect. When leveled per the POH, the factory distance figure was spot on.
Just sayin'
Old August 28th 13, 07:30 PM
Brad Alston Brad Alston is offline
Member
First recorded activity by AviationBanter: Jun 2011
Just sayin'
Same "previous owner" for both ships? Now that would be an interesting twist! I assume the measurement units were consistent between the factory and previous owner...just thinkin'!
Brad.
Old August 28th 13, 08:17 PM posted to rec.aviation.soaring
Uncle Fuzzy[_2_]
In BOTH the Speed Astir and Janus C log books, some previous owner had made pen-and-ink' changes to the distance from the main wheel to the tail wheel. In BOTH cases, the factory figure was correct, and the ink changes incorrect. When leveled per the POH, the factory distance figure was spot on.
Just sayin'
No, different 'previous owners. The measurements that they 'inked' into the log books were accurate - with both wheels on the hangar floor. Unfortunately, that's not what the POH calls for. Both manuals specify 'level' and the Janus, (if I remember) actually gives a distance. from the floor to the tailwheel.
(which, conveniently corresponds to the height of the box the scale comes in.
Is he difference significant? I doubt it. But I'm kinda' OCD about specifications (also why I won't use RG-58 for L band (yet another rant.
LOL
Old August 29th 13, 01:31 AM posted to rec.aviation.soaring
Don Johnstone[_4_]
At 09:30 28 August 2013, Uncle Fuzzy wrote:
I have a sample size of TWO, so take this or leave it. =20
made=
wheel=
incor=
Just sayin'
I am really struggling to understand your point. The distance between the
mainwheel axle and the tailwheel axle is always going to be the same
irrespective of the position of the glider. I suppose you could get minor
differences because of expansion but I would have thought that they were
not measureable.
The distance between two points on the ground, described by a line drawn
perpendicular and passing thought the axle centres will of course vary
depending on the attitude of the glider in relation to the ground.
Both measurements are needed.
Old August 29th 13, 05:36 AM
Member
On Wednesday, August 28, 2013 2:30:05 AM UTC-7, Uncle Fuzzy wrote:[color=blue]
No, different 'previous owners. The measurements that they 'inked' into the log books were accurate - with both wheels on the hangar floor. Unfortunately, that's not what the POH calls for. Both manuals specify 'level' and the Janus, (if I remember) actually gives a distance. from the floor to the tailwheel. (which, conveniently corresponds to the height of the box the scale comes in.
LOL
[/blue]
What?...you mean we should read AND understand the POH!? Hmmmm...when you are throwing your person into the air and trusting in laws of physics and someone else's engineering, I would think accuracy counts! But then again, that's just me thinkin' again!
Brad.
Old August 29th 13, 10:31 AM posted to rec.aviation.soaring
Bob Cook[_2_]
What you say is true...but the op points out that the inked in W&B used
what you said in your first paragraph, when they should have used the
second........
Over the years I have watched and laughed.... mechanics, glider pilots,
home builders etc. really can't seem to do an actual weighing...
One funny example I've seen more than once... is doing a glider weighing
OUTDOORS!!!!
Gliders and airplanes are like women...they seem to somehow gain a pound or
two each year!
Cookie
made=
wheel=
incor=
on.
Just sayin'
not measureable.
Old August 29th 13, 02:04 PM posted to rec.aviation.soaring
GC[_2_]
made=
wheel=
incor=
Just sayin'
not measureable.
No. Gliders with trailing link suspensions have a variable distance
between the axles depending on mass and attitude.
No. UF is right. Only the distance between perpendiculars is needed.
The actual distance between axle centres is irrelevant. Whoever defaced
his book needs to go back to weighing school.
The process we go through to find a glider's CG position only finds a
'y' axis figure. By defining the attitude when the weighing is done, we
remove a degree of freedom which makes the process much simpler - but
accurate attitude setting is essential.
GC
Old August 29th 13, 07:38 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Brad Alston wrote, On 8/28/2013 9:36 PM:[color=blue]
'Uncle Fuzzy[_2_ Wrote:
;844103']On Wednesday, August 28, 2013 2:30:05 AM UTC-7, Uncle Fuzzy
wrote:-
rant.
LOL-[/blue]
The difference in the two measurements is small (1% or so) and therefore
irrelevant. The critical measurement that will be strongly affected by
measuring in the wrong attitude is the distance of the main wheel axle
from a datum point; in the case of my ASH 26 E, that datum point is the
leading edge of the wing at the root. A 1" error in this measurement
means a 1" error in the location of the CG - a substantial error on wing
chord of only 33".
email me)
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm
http://tinyurl.com/yb3xywl
Old August 29th 13, 09:43 PM posted to rec.aviation.soaring
Craig Funston[_2_]
On Thursday, August 29, 2013 11:38:23 AM UTC-7, Eric Greenwell wrote:[color=blue]
wrote:-
rant.
LOL-[/blue]
chord of only 33".
email me)
The weight distribution between the main wheel and the tail wheel/skid changes with the aircraft attitude because the vertical CG is above the tire contact patch. Like the others have said. Follow the manual.
Craig
Old August 30th 13, 02:10 AM posted to rec.aviation.soaring
GC[_2_]
On 30/08/2013 04:38, Eric Greenwell wrote:[color=blue]
wrote:-
rant.
LOL-[/blue]
chord of only 33".
You're right - but it's actually worse than that, Eric. On my glider
the distance from datum to axle centre is only about an inch. The
percentage error in this measurement (especially given the usual
conditions under which it's obtained ) is likely to be quite high. Also
the solution to the equation is a small difference between two large
numbers. The whole process is very error-prone.
GC
PA-32 Weight and Balance John Doe Owning 14 May 23rd 06 01:03 AM
L23 weight and balance Tony Verhulst Soaring 5 December 31st 05 01:54 AM
Weight & Balance DVD jon Home Built 0 October 8th 05 05:39 PM
Weight and Balance Dale Larsen Home Built 2 June 23rd 04 05:11 PM
Weight and balance.. Bart Rotorcraft 9 August 19th 03 02:57 AM
