Panel Mount Digital Volt Meter
Old October 29th 13, 04:53 PM posted to rec.aviation.soaring
Dan Marotta
Default Panel Mount Digital Volt Meter
Looking for a very small, simple, panel mount DVM. I've looked all over
eBay and Amazon and haven't found anything that suits my needs.
I can find plenty of LED versions, but they likely won't be satisfactory in
bright sunlight, and all the LCD meters I can find are huge. Something on
the order of 1/2 inch high by 1 1/2 inches wide, by 1/4 inch thick, that
could simply be gluded to the surface of the panel with a small hole to feed
the wires through would be ideal.
Just like OAT, I like to know my current power situation without fiddling
with the 302.
Old October 29th 13, 05:41 PM posted to rec.aviation.soaring
Soartech
Here is one that is 0.82 inches high and 1.73 inches wide.
https://www.jameco.com/webapp/wcs/st...001_2095040_-1
Supply current is only 3 mA.
Old October 29th 13, 05:48 PM posted to rec.aviation.soaring
JS
Easier than 302... See if there's one in your moving map display or COM radio.
Some examples:
ClearNav can be set to display a meter only when the battery drops to a user-selected voltage. AR6201 and I believe 4201 show voltage when in frequency adjust mode.
Old October 29th 13, 06:00 PM posted to rec.aviation.soaring
Dan Marotta
That's the one!
Thanks, I've been looking for days.
"Soartech" wrote in message
Old October 29th 13, 10:15 PM posted to rec.aviation.soaring
JohnDeRosa
Here is the voltmeter that I use - the Lascar EM1200. http://www.lascarelectronics.com/tem...datalogger=116
What is so nice about this unit is how it mounts using only one threaded (hollow) stud through which all the wires run. Drill one hole and you are set. Great stuff.
There is also an analog version. http://www.lascarelectronics.com/tem...datalogger=111
Simpler still is the single multi-color LED from http://www.gliderguider.net/batttery_monitor.htm.
Enjoy! - John
Old October 29th 13, 10:18 PM posted to rec.aviation.soaring
Kimmo Hytoenen
If you use IOIO card for communication and XCSoar or TopHat SW
you can use battery voltage infobox.
-kimmo
Old October 30th 13, 01:27 AM posted to rec.aviation.soaring
Dan Marotta
The battery info box on my Streak running XCSoar (Top Hat is based on that)
shows only percent of charge of its internal battery.
"Kimmo Hytoenen" wrote in message
-kimmo
Old October 30th 13, 10:16 AM posted to rec.aviation.soaring
Jim White[_3_]
At 17:00 29 October 2013, Dan Marotta wrote:
That's the one!
Bought and fitted one of these. Threw it away when it failed a month later!
Old October 30th 13, 06:04 PM posted to rec.aviation.soaring
Soartech
Then you lost your $34. Should have returned it. A certain small percentage of electronic devices are subject to "infant mortality". Sorry you were the unlucky one that time. All high reliability electronics (jet engine fuel controls for example) are subjected to a lengthy burn-in period in a temperature chamber to weed out bad parts. But this is expensive and is not done for inexpensive consumer electronics.
Old October 31st 13, 12:58 AM posted to rec.aviation.soaring
Kimmo Hytoenen
The voltage measurement is made in the IOIO card using analog
input. And you have to select voltage measurement under devices
menu.
based on that)
SW
-kimmo
Good Digital Water Meter Wanted Paul Remde Soaring 11 April 7th 11 02:25 AM
Panel mount IFR GPS for training ... Bud_of_yours Piloting 23 December 24th 06 07:38 PM
Delcom 960 Panel Mount....... [email protected] Aviation Marketplace 0 June 27th 06 04:17 AM
digital air-speed meter can be used in car? [email protected] Home Built 17 May 30th 06 03:42 AM
Panel volt meter Bob C Soaring 10 January 13th 05 01:00 PM
