I tried various keywords on Google but couldn't come up with the answer
to my question. Does a general aviation industry exist in mainland China? I'm planning a vacation trip there in 2005 and, if it is possible, would like to arrange for two or three hours of dual instruction in a spam-can. Regards, Casey Wilson Freelance Writer and Photographer |
![]() "Casey Wilson" wrote in message news:vTbkc.2477 I tried various keywords on Google but couldn't come up with the answer to my question. I am at a loss to understand why. I tried various keywords on Google (specifically 'china', 'private airplane', and 'general aviation') and came up with over 26,000 hits. Three minutes worth of browsing indicates that there is in fact a very rudimentary general aviation industry in China, there seem to be a very few operators who can fill your needs if you're in the same city as they are, and (it seems) you are willing to pay the freight in advance. I particularly like http://www.camptour.com/aviation/ |
![]() "John Gaquin" wrote in message ... "Casey Wilson" wrote in message news:vTbkc.2477 I tried various keywords on Google but couldn't come up with the answer to my question. I am at a loss to understand why. I tried various keywords on Google (specifically 'china', 'private airplane', and 'general aviation') and came up with over 26,000 hits. Three minutes worth of browsing indicates that there is in fact a very rudimentary general aviation industry in China, there seem to be a very few operators who can fill your needs if you're in the same city as they are, and (it seems) you are willing to pay the freight in advance. I particularly like http://www.camptour.com/aviation/ This is getting off topic, but strange. I entered China+"general aviation" into Google and got zero hits. When I changed the order to "general aviation"+China, Google came back with 26,300 hits. I never knew Google was sensitive to order of appearance. John, thanks for the help. |
.. . This is getting off topic, but strange. I entered China+"general aviation" into Google and got zero hits. When I changed the order to "general aviation"+China, Google came back with 26,300 hits. I never knew Google was sensitive to order of appearance. It's not. It's sensitive to your use of the "+" character, which has no meaning to Google for a search. While "+" character is meaningless for the search, for whatever reason (probably a bug) gets appended to the word "china" for the search when you put the word "china" before the phrase "general aviation". When you enter it in the other order, the "+" character is stripped from your search, allowing actual hits (the text "china+" doesn't match anything, not surprisingly). If you enter the search text, run the search, and then click the "Advanced Search" link, you can gain some insight into how Google is parsing your search text. Doing so reveals the above. Bottom line: you will get a lot more utility out of Google if you stop putting "+" characters into your search text. My guess is that you've had lots of trouble using Google as a result of this user error, if it's something you've expected to work for any significant amount of time. Pete |
![]() "Peter Duniho" wrote in message ... "Casey Wilson" wrote in message .. . This is getting off topic, but strange. I entered China+"general aviation" into Google and got zero hits. When I changed the order to "general aviation"+China, Google came back with 26,300 hits. I never knew Google was sensitive to order of appearance. It's not. It's sensitive to your use of the "+" character, which has no meaning to Google for a search. some of Pete's text is deleted here Hmmm, the + and - signs have always been shorthand conventions in Google and other search engines. See: http://www.google.com/help/basics.html where it states; "If a common word is essential to getting the results you want, you can include it by putting a "+" sign in front of it. (Be sure to include a space before the "+" sign.)" The article does imply that common words a who, what, how, etc. but the parser will use the operator on any word. I will however concede to improper use by failing to insert the requisite space. Inserting the space does seem to fix the problem, but not quite. The keywords china + "general aviation" bring up a slightly different set than "general aviation" + china. I'll figure that out. I do thank you for making me refresh my use of the logical operators. Either the engine designers have made some changes in the parsing rules, or I've picked up many bad habits. I prefer to believe the former mostly, with a tiny bit of the latter. |
... Hmmm, the + and - signs have always been shorthand conventions in Google and other search engines. See: http://www.google.com/help/basics.html I have seen it. You are misreading it. There is no reason to use the "+" sign in conjunction with a word other than what they consider "common" (generally pronouns, conjunctions, prepositions, etc.). But more importantly, you were not using the "+" sign in the manner that Google expects it. You used it as a conjunction between your search terms, as a synonym for the "AND" operator. But in Google searches, the "AND" operator is implied, and there's no such thing as an "OR" operator. When using the "+" to make clear that you require a word that would otherwise be ignored in the search, it must PREFACE the word of interest. In any case, neither of the terms you were using -- "china" and "general aviation" -- would have been excluded from your search. Google will tell you when it's ignoring a word, so the right thing to do is always not bother with the "+" operator, and only use it if it tells you it's ignoring a word in your search text that you feel ought to be included. I suppose you felt it necessary to take me to task for saying the "+" character has no meaning to Google for a search. If you think it has meaning, you're welcome to that opinion. I have been using Google since nearly the day it was born, and I have yet to run into a search where the "+" character added anything to the search. The words Google ignores are useless words and including them never makes the search more useful. I stand by my claim that the "+" character has no meaning to Google. It respects it, but it doesn't do anything useful with it. It certainly has no idea what YOU meant when YOU used it. I suppose there are people around who can accept advice and assistance when offered without starting an argument with the person who offered the advice and assistance. But it remains clear that they don't use the Usenet. Pete |
![]() Casey Wilson wrote: This is getting off topic, but strange. I entered China+"general aviation" into Google and got zero hits. When I changed the order to "general aviation"+China, Google came back with 26,300 hits. I never knew Google was sensitive to order of appearance. If you entered exactly what you just described, that's an interesting result. The first query will find all items which have the term "general aviation" in them. The word "China" is optional. The second query will find everything with "China" in it. The term "general aviation" is optional. If indeed you have no spaces in the first query, that might explain why it returned no results. In that case, it will only return links to articles which have the string 'China+"general aviation"' in them, and I'd bet there aren't too many of those. George Patterson If you don't tell lies, you never have to remember what you said. |
"G.R. Patterson III" wrote in message
... If you entered exactly what you just described, that's an interesting result. The first query will find all items which have the term "general aviation" in them. The word "China" is optional. Google doesn't have the concept of "optional" words for the search text. The second query will find everything with "China" in it. The term "general aviation" is optional. Ditto. If indeed you have no spaces in the first query, that might explain why it returned no results. In that case, it will only return links to articles which have the string 'China+"general aviation"' in them, and I'd bet there aren't too many of those. Actually, it returns all of the pages with both the term "china+" and the phrase "general aviation" in them. There are only about 2400 pages with "china+" in them, and none contain the phrase "general aviation". Pete |
![]() "Casey Wilson" wrote in message ... I tried various keywords on Google but couldn't come up with the answer to my question. Does a general aviation industry exist in mainland China? I'm planning a vacation trip there in 2005 and, if it is possible, would like to arrange for two or three hours of dual instruction in a spam-can. GA is in its infancy in China. Until very recently, China sent all would-be pilots out of country for initial training up through instrument rating, multi-engine, and commercial before bringing them back to work for the national airline. The United States got a lot of them. Right now China is beginning to develop a GA market to generate their own pilots and to provide better support for tourism, skydiving, and the 2008 Olympics. Last I heard, there were still less than 400 GA aircraft in China. If there any airplanes for rental in China, it would be at Beijing Sport Aviation School or at Anyang Sport Aviation School in Beijing. A company called PTE is the Cessna agent in China and handles Cessna sales and service. Anyang and PTE are the operators of A&P Light Aircraft Service. |
C J Campbell ) wrote:
: : : Last I heard, there were still less than 400 GA aircraft in China. If : there any airplanes for rental in China, it would be at Beijing Sport : Aviation School or at Anyang Sport Aviation School in Beijing. A company : called PTE is the Cessna agent in China and handles Cessna sales and : service. Anyang and PTE are the operators of A&P Light Aircraft Service. : : http://english.peopledaily.com.cn/20...1_101815.shtml Huge Market for General Aviation in China "...In 2001 more than 300,000, or 70 percent, of the world's total of 460,000 planes were used in general aviation, statistics show..." --Jerry Leslie Note: is invalid for email |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
New aviation history interview: Fokker/Curtiss/Messerschmitt ace Mauno Fräntilä | Jukka O. Kauppinen | Military Aviation | 0 | September 22nd 04 11:18 PM |
SJSU Aviation Program Closure | Troy Towner | Aviation Marketplace | 0 | June 17th 04 07:52 AM |
General Aviation Legal Defense Fund | Dr. Guenther Eichhorn | Home Built | 3 | May 14th 04 11:55 AM |
General Aviation Legal Defense Fund | Dr. Guenther Eichhorn | Aerobatics | 0 | May 11th 04 10:43 PM |
